Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Base Camp
Old 02-22-2019, 05:50 PM   #1
Lee-Robert's Avatar
2017 Basecamp
Albuquerque , New Mexico
Any recommendations on portable solar panel units?
Now that my Basecamp is in covered storage the factory installed solar panels on the roof can't keep the batteries charged. I need to locate a good option for a portable solar panel setup to connect to the exterior solar panel connection.
Lee-Robert is offline   Reply With Quote
Old 02-22-2019, 07:04 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Get a portable Eclipse solar panel from Renogy. Then the engineering fun begins!!!
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 02-22-2019, 09:01 PM   #3
Registered User
2016 25' Flying Cloud
Fairfield , California
I bought 3 flexable panels, wiring and a solar charger and built my own. Renogy has great parts including a good flexable panel and a great water proof solar charger that are on sale right now.
Matti
Mattirs is offline   Reply With Quote
Old 02-22-2019, 09:41 PM   #4
dznf0g's Avatar
Oswego , Illinois
Matti
I bought a 160watt zamp suitcase a number if years ago. Very happy with it. In the meantime I schooled up on solar systems, so when my son wanted one, I built a suitcase with two renogy 100 watt panels for about half the money.
-Rich-
Old 02-22-2019, 10:22 PM   #5
2017 27' International
Lake Havasu City , Arizona
Food for thought: Renogy's "Compact Design" 100 W rigid panels (which at $113 look like the current best buy) are performance warranted (90% of rated output) for 10 years. Renogy's 100 W flexible panels are performance warranted for 0 (yes, zero) years.
I've had flexible panels. I've seen them fail after a year or so. I use rigid panels on the ground now. Bonus: they cost half as much per watt as the flexibles.
Paprika is offline   Reply With Quote
Old 02-23-2019, 06:01 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I use a 100 watt Renogy suitcase panel. No complaints and it has kept me going for over a week (then I moved, I didn't run out of juice).
2019 Ford Expedition Platinum
Old 02-23-2019, 07:00 AM   #7
centennialman's Avatar
2016 23' International
Centennial , Colorado
I have a Renogy 200 watt suitcase set up. Works well and easy to transport.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 02-23-2019, 08:58 AM   #8
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
This is what I have and with 30' of cable.
The legs are not the best design but get the job done.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 02-23-2019, 09:19 AM   #9
2012 25' FB Flying Cloud
Portland , Oregon
I like the Zamp 90W foldable which packs in front trailer compartment on my 25 foot Flying Cloud. They have SAE connector / solar port to mount outside battery box so you plug into the port rather than open battery lid to hook up alligator clips on battery terminal - simple and elegant. Also I have Zamp solar panels on top and 500W controller. Zamp is a good design and their engineers take phone calls with your questions.Happy with Zamp 7 years running!
Hophead is offline   Reply With Quote
Old 02-23-2019, 10:09 AM   #10
CAV
CAV's Avatar
2004 25' International CCD
Dubuque , Iowa
Have Go Power 120 portable panels (suitcase) . Plugs into 7 pin to charge. See ad in Airstream Life store.
CAV is offline   Reply With Quote
Old 02-23-2019, 11:20 AM   #11
iaqstuff's Avatar
2013 Interstate Coach
Yarnell , Arizona
Just make sure the connections are compatible. I have two Goal Zero 100 Boulder suitcases. I like them, but their proprietary connections are a problem.
iaqstuff is offline   Reply With Quote
Old 02-23-2019, 07:50 PM   #12
2Dreamin's Avatar
Panama City Beach , Florida
We bought a Zamp 160 watt portable suitcase. We had a quick disconnect installed on our coach and then purchased an extension cord so that we had more options when moving it around to catch the 'sun'
Diane
2Dreamin
2016 Interstate Grand Tour Ext.
2Dreamin is offline   Reply With Quote
Old 02-24-2019, 07:15 AM   #13
Lee-Robert's Avatar
2017 Basecamp
Is it waterproof? Can you post the model number?
Old 02-24-2019, 09:24 AM   #14
DaveP's Avatar
2004 28' Classic
Monument , Colorado
The Renogy suitcases with controller have waterproof controllers. What I did with my 200 watt Renogy suitcase is put the MPPT controller inside the trailer. I used 6 gauge, highly flexible welding wire with Anderson Power Pole connectors to make a 30 foot extension cable. I also made a 10 foot cable for when the sun will be on the front of the trailer all day long.
DaveP
2023 Ram 3500 4x4
Old 02-24-2019, 01:19 PM   #15
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
As an alternative to a suitcase, just get a couple of 100 watt panels, about 40-60 feet of solar cable and a Victron solar controller. This will perform better than a suitcase and only cost about $400. You can also mount it permanently down the road on your Basecamp or another Airstream.
There is no need to go any larger than #10 wire as the current is only about 5 amps if you connect your panels in series.
DanClick image for larger version
ID:	334256Click image for larger version
The next photo was taken when the solar output was much higher, about 175 watts from the panels (based on the Victron controller) and 167 watts into the batteries (based on the Trimetric).Click image for larger version
ID:	334258Click image for larger version
ID:	334259Click image for larger version
Old 02-24-2019, 01:45 PM   #16
Registered User
I waited for the panels went on sale, this helped on pricing, so far mine have lasted over two years.
What I like about flexable panels is that they are light and very easy to store.
Matti
Old 02-25-2019, 10:15 AM   #17
2017 30' Flying Cloud
Astoria , Oregon
Dave-We have the 200 w suitcase from Renogy and the reverse polarity adaptor to connect to Zamp solar plug. It still does not work through the plug. If we hook up to battery directly works fine. Did you have problems with the Zamp solar plug? We can’t figure it out.
tschambo is offline   Reply With Quote
Old 02-26-2019, 06:58 AM   #18
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Hi tschambo,
If you are asking me (DaveP), I cannot answer from experience. I do not have any Zamp equipment. If it is just reverse polarity, then I would say that you might have some bad crimps or a faulty adapter.
DaveP
2023 Ram 3500 4x4
Old 02-26-2019, 07:39 AM   #19
"Cloudsplitter"
Yes>>
Our Zamp has stayed out...but really it's not a concern they are portable after all. 🤔
I fold 'em up and put 'em in the Burb right after I roll up the awning. 👍
ID:	334479   Click image for larger version
Old 03-03-2019, 11:24 AM   #20
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
Los Osos , California
I have both the ZAMP 160 for a 2 x 6 volt AGM trailer and a ZAMP 120 for the single 12 volt AGM trailer. Both work very well.
I opted for the made-in-the-USA ZAMPs instead of the Canadian based Renology and Go Power! Valterra Power panels. I've read that people have had difficulties with warranty issues with the Cnadian companies.
SilverWind is offline   Reply With Quote
Can a portable solar panel be added to a factory solar system? larry9000 Generators & Solar Power 7 10-14-2017 04:35 PM
Recommendations for portable solar panel kit? jagzoo Generators & Solar Power 37 03-06-2017 08:28 PM
Any updated portable solar panels recommendation? Vitaver Electrical - Systems, Generators, Batteries & Solar 15 10-24-2016 04:04 PM
Are all A/C units Rooftop units? jrsygrl Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-19-2013 08:23 PM
Vintage Units VS New Units Cstar On The Road... 4 05-07-2004 09:22 PM
