Old 10-08-2008, 10:53 AM   #1
1970 31' Sovereign
Apple Valley , California
original interior wall covering
I'm trying to find out what the orginal wall covering is in a '70 Sovereign. Does anyone know and also how to safely remove white paint the previous owner applied to it? Also, how do I clean the orginal wall covering once I have removed the paint? Anyother advice about this would be appreciated. Thanks, Beverly II.
Beverly II is offline   Reply With Quote
Old 10-08-2008, 11:14 AM   #2
Seymour1971's Avatar
1971 21' Globetrotter
Western US Cities , CA,AZ,NV,UT,OR,WA
Beverly,
We have a 71 GT so I am not certain we have the same wall covering material but I would guess we do. Our material appears to be a vinyl over aluminum. Ours was sticky to the touch. I used warm & Dawn followed by a solution of bleach & water. This seemed to get rid of the sticky feel as well as remove some of the staining. Hope this helps. As for removing paint from a painted surface. I have yet to find a save alternative that actually works as detailed on the package. Depending on the condition of the paint, more good than bad, have you considered just cleaning, priming, and then repainting it? Sometimes repainting turns out to be the safest alternative. Good luck.
m
Seymour1971 is offline   Reply With Quote
White fuzzy wall covering grantb4 Upholstery, Blinds, Walls & Interior Finishes 3 08-16-2007 08:38 AM
interior wall covering material mouse 1987 - 1989 Excella 2 04-09-2007 04:11 PM
Interior Wall and Ceiling covering PhiDor Upholstery, Blinds, Walls & Interior Finishes 16 09-30-2006 09:11 AM
Shower vinyl wall covering replacement. capehoorn Sinks, Showers & Toilets 0 05-19-2006 02:03 PM
Delaminated wall covering? balrgn Upholstery, Blinds, Walls & Interior Finishes 15 02-20-2006 12:09 PM
