Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 02-12-2015, 03:51 PM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Aluminum rivets with aluminum mandrels are very common. The package should be labelled. Aluminum/Aluminum should be the only rivets used to prevent oxidation.
Old 02-12-2015, 05:02 PM   #22
gecko's Avatar
2009 28' International
Pacific Palisades , California
Steel and aluminum--a potentially corrosive mix if you're near a salty environment. There are definitely all aluminum rivets available, and that's what you should be using! They are less strong than steel, but if there enough if them and of sufficient diameter, they'll do the job. Also easier to pull and less likely to scratch--that's why the blue painters tape is to be used, too.
gecko is offline   Reply With Quote
Old 02-12-2015, 05:19 PM   #23
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Thanks - I'll be looking for the alum/alum designation in future. I think pretty much all the pop rivets I have on hand are likely alum/steel.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 02-12-2015, 06:51 PM   #24
2003 31' Classic
Terra Alta , West Virginia
How do you know if there is a broken rivet on AS' s like my 03 classic with covered interior? Maybe ignorance is bliss?!?
DAVE THE NEW STREAMER
wvstreamer is offline   Reply With Quote
Old 02-14-2015, 08:59 AM   #25
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Dave, either the head will have popped off or you'll notice the seam isn't fastened behind the head if it's sheared off in between.
I am getting started putting my inside skins back. I started with some rivets from VTS and found they left a nice clean head when they popped. Then I got some more rivets from Harbor Freight and found the shanks wouldn't pop off or even when they did they'd leave a protrusion and looked bad even after grinding.
Take away, VTS has the right sizes and what seems to be better quality than I can find locally.
'61 Safari
https://airwave503.blogspot.com/
Airwave503 is offline   Reply With Quote
Old 02-14-2015, 10:59 AM   #26
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
VTS sells all aluminum rivets vs. the aluminum with steel mandrel rivets you typically find at local and big box hardware stores. The aluminum mandrel is preferred and makes for a cleaner release.
Bob Martel
WBCCI# 5766
Old 02-14-2015, 11:18 AM   #27
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Huh, the ones I got from Harbor say Aluminum but they sure don't break off clean. And no way I am going to risk having steel fastened to any aluminum having seen what mixed metal connections have done over the years already. Thanks.
'61 Safari
Old 12-18-2015, 02:36 PM   #28
2015 25' International
Southern CA , California
So is there typically a gap between the interior aluminum skin and the rib it's attached to? I lost one of my 2015 International Signature 25 and I was trying to determine where it fastens to the rib or other material but poking back there all I can feel is what I believe to be a rib with about 1/4" gap between the skin and rib, does this make sense? I tried pushing on the skin to make sure it's where it should be and there doesn't seem to be enough flex for it to have ever been directly on the rib. This is on the curved skin extending to the ceiling in the bedroom.
Any help is much appreciated.
Thanks!
Zach
deadlock is offline   Reply With Quote
Old 12-19-2015, 08:54 AM   #29
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
One thing I've learned. If you find an inordinate number of rivets shearing off, check your hitch setup. Having your hitch set up correctly creates less stress for the unit.
Ronman is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
'89 Excella, What size were the really big rivets that hold up the cabinets? mikeandnora Cabinets, Counter Tops & Furnishings 0 05-05-2012 01:21 PM
Can the interior/bathroom wall hold two LCDs? dre00 Audio, Video & TV 3 06-22-2009 08:14 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
They don't make them like they used to femuse Our Community 23 04-29-2003 07:15 AM
