10-03-2017, 06:39 PM
2023 23' Flying Cloud
2014 30' International
Pagosa Springs
What's behind door #1
I cannot figure out if this is actually a door. It has a knob and hinges at the bottom but it doesn't want to open. I have tugged on it almost to the point of breaking something. It is in the bathroom of a 2003 Classic 25' I just purchased. Any ideas what is going on?
10-03-2017, 06:41 PM
Retired.
, At Large
Originally Posted by Rbarlow
Attachment 296156
Looks like access to the rear of the water heater.
10-03-2017, 06:48 PM
2000 25' Safari
Denver
, North Carolina
I had a door like that but it ended up being velcroed. I was sure I was breaking something. I just stared at the corner and worked it down and off. Maybe obvious, have you searched from the otherside / outside?
10-03-2017, 07:21 PM
Pagosa Springs
The water heater is further to the rear. I believe the wheel well is behind it.
It doesn't even look like a door. The sides seem sealed. It's just weird that it has hinges and a knob.
10-03-2017, 07:28 PM
2004 28' Classic
Monument
Looks to me like it is intended to open in??? Did you push in?
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
10-03-2017, 07:33 PM
1995 25' Excella
xxxxx
, xxxxxx
My trailer has one like it. The fender well is behind it. You can get to some plumbing through it. I don't want store anything hard in there that might damage the wiring or plumbing. I put toilet paper and paper towels in it.....it just pulls open.
10-04-2017, 09:38 AM
2013 30' Classic
Greenwood
, Mississippi
That's what I was thinking...
Maybe it is access to the water heater bypass or some plumbing or wiring or all of the above...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
10-04-2017, 11:05 AM
2012 23' FB International
Woodstock
, Ontario
Yes it covers the fender well and some piping
I use it to store my tank treatments and spare water pump. Stuff does fall forward of the wheel well and is difficult to retrieve
The door is hinged on the bottom and is typically very difficult to open since the catch is seldom operated... "pull Hard"
JCW
10-04-2017, 11:08 AM
2013 30' Classic
Greenwood
, Mississippi
Try wiggling up and down and left and right while pulling...
TAC #MS-10
Airforums #70955
10-04-2017, 11:32 AM
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg
Does the know turn at all?? Might need to run a blunt blade or credit card around the edge to loosen the seal.
10-04-2017, 04:49 PM
1976 31' Sovereign
2004 22' International CCD
Cleveland
, Oklahoma
Hmmm.
The door or your body?
10-04-2017, 05:11 PM
Pagosa Springs
I pulled as hard as I am comfortable doing. Something Is fixing to break. Since the reward is possibly only a very small area behind the door, I am not going to risk tearing it up.
10-04-2017, 05:46 PM
1972 25' Tradewind
St Clair County
, Michigan
Even if no one else did, I saw what you did there! Funny!
12-07-2017, 11:41 PM
Thunder Bay
, Ontario
If you zoom in it looks like there's screws driven in from above down into the door on either side of the knob...
12-08-2017, 02:19 AM
2012 27' Flying Cloud
W
, New England
Yes. And it looks like there are two lines marking their location as if the previous owner did that to make finding them easier.
Look at the knob, go up to the trim and about 2" to the right and left you'll see the marks. See if there are screws there / take them out and either push in or pull out. I'm betting you push in but I don't know for sure.
12-08-2017, 04:11 AM
Sag Harbor
, New York
Ditto. Good catch Richie1983, and welcome to the forum!
It is also possible, however, that those are two small "set screws" driven UP into the bottom of the "head casing" trim IMO. Guessing that the catch behind the top of the door may be a "push to open" latch. Do you have others like this? They are often brown plastic, and can fail in the "locked" mode unfortunately. They can also fail to lock, especially with road vibration, so the prior owner may have installed set screws to keep the door closed.
Rbarlow, can you take a photo from floor level looking up at the area above the pull/knob?
Peter
