Old 01-26-2011, 08:24 AM   #41
OO , OO
Send a message via Skype™ to cruiser54
In the ledge is a rail, the table is quite easy in it hung up....!
If I the table leg to snap makes, the table can be moved even more....
cruiser54 is offline   Reply With Quote
Old 01-26-2011, 08:43 AM   #42
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by casarodante View Post
The second one, the hinge, is what is my father used in one of his Airstreams. I remember he also put one on the outside of the trailer by the wheel well so we could take the table outside to eat.
Exactly what I did, except that on a Caravel, there isn't enough space on the side of the trailer with the door open, so I put the second rail on the inside of the door and attach the table outside with the door open. You will want an adjustable leg if you do this as the ground outside is usually uneven so the table will not be level. If it is not nice enough outdoors to keep the door open, we don't want the table outside anyway.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 01-26-2011, 08:50 AM   #43
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
In the lower diagram above; the 2 rectangular items above the table are where the table "Clips" in to hold it to the wall. Note how the table just pivots on the "U" shaped bar from the upper to lower position.
Old 01-26-2011, 01:13 PM   #44
lucymcdog's Avatar
1965 24' Tradewind
Starkville , Mississippi
When the table is on the ledge rail, what keeps it in place when traveling? Doesn't it bounce out?
lucymcdog is offline   Reply With Quote
Old 01-26-2011, 01:27 PM   #45
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Table moving.
Lindy; If you are talking about the rail where the table slides in from the end or side; it might move a little but I have never had one slide all the way out or even much more tha an inch. With the leg on the floor; if the table does move any the leg will cause it to bind in the track or rail and it won't move anymore.
I'm not sure about the "u" Shaped bracket since I don't have one but would assume that the latches are spring loaded or something to keep the table from bouncing out.
Old 01-26-2011, 02:03 PM   #46
OO , OO
I have such a rail in mine Travel-mobile. At the table 2 buttons are to fix, he cannot slip away. It has never happened a little bit!
Greeting Werner
(Excuse my English, I must translate everything with the computer, grin.)
Old 01-27-2011, 07:41 AM   #47
lucymcdog's Avatar
1965 24' Tradewind
No, I was wondering how the setup from the guy in Bern was. It sounded like he just had a ledge that the table fit into. I was thinking perhaps I could bevel the edge of a piece of wood the width of the table (maybe 30 degree bevel), attach that to the wall with the bevel up, make another piece with the bevel down and attach that to the table then just put one inside the other. Problem is, how could I make it not bounce out when traveling? Any ideas?
We sort of lost our focus on building the dinette when we ran out of materials so we started on making a cabinet for the shelf that runs across the back of the trailer over the bed. And, we did it! Compound curves and all - thanks to your method of scribing to get the curves right. It is being stained and polyurathaned but we should be able to get it up in the next day or so. I'll post pictures when it's done.
I've ordered some grill material for the panels in the benches and, of course, it will take over a week to get here so that is yet another delay.
I do have a question though about the cushions that maybe you, or somebody else, can answer. The cushions will fit into the front curve of the trailer - not a problem for the SEAT cushion, but how do you make the seat back cushion in the curve? Or do you just not have a seat back there since nobody can really sit there anyway? Does that make sense? Maybe it just sort of falls into place and ends when it ends?
Also, is there a good source of 5" foam available on the internet that anybody knows about? I am over 3 hours away from a JoAnn's and the last foam I got there was really kind of wimpy and smushed down after a couple of years. I'd like something that is durable and will last because it is not my favorite thing to make seat cushions.
Lindy
Old 01-27-2011, 08:56 AM   #48
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Cushions.
Question:
Answer:
In my situation the cushions don't go into the curved part at all. I'm going to be working in my trailer today. I'll make an attempt to get better photo's of how I made it work. I'll post them later today.
I had my cushions made by an upholstery shop. Not cheap!
Just type in "best foam for seat cushions" into Google.
Old 01-27-2011, 10:23 AM   #49
2020 27' Globetrotter
1999 25' Safari
Somewhere , Ohio
Do you have an "Army/Navy Surplus" store around you? I know of a lady who used to buy her foam there. (Since I am in the business, I have a supplier I get all of mine from for wholesale pricing.) I would imagine shipping would not be cheap if you have to buy online, so I guess, considering you are in Colorado, I'd try to make certain the supplier would be on the West coast vs. East coast.
Deb
(Now "Air Cruiser", formerly "D. Hall".)
Air Cruiser is offline   Reply With Quote
Old 01-27-2011, 11:31 AM   #50
Mantua , Ohio
That table setup looks like the factory one in some newer AS. zz
Old 01-27-2011, 03:39 PM   #51
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Pics
Here are some shots of the Right Front Corner. Looking down on the right hand front corner.
ID:	120229   Click image for larger version
Name:	Top View 2.jpg
Name:	Top View 4.jpg
Old 01-27-2011, 03:44 PM   #52
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Question:
Answer:
Our back cushions (look at the pic with the table down & the cushions made into a bed on my webpage) don't follow the curve either. We made ours with an angle, then have two wedge-shaped cushions to fill-in when we make it into a bed. You could also make rectangle backs and one larger rectangle filler cushion if you want. Another idea if you don't want filler panels I've seen is putting either snaps or velcro on the back of the cushions to keep them in place and follow the curve of the wall - but then the cushions have a "right" & "wrong" side.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-27-2011, 03:45 PM   #53
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
More Pics
With cushions in place. Looking down.
Name:	Right Front Corner 3.jpg
ID:	120232   Click image for larger version
Name:	Top View 5.jpg
Old 01-27-2011, 03:49 PM   #54
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Even More Pics
Name:	Right Front Corner.jpg
ID:	120234   Click image for larger version
Name:	Right Front Corner 2.jpg
Old 01-27-2011, 03:56 PM   #55
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Table Leg
A couple of shots of the table leg and foldup mechanism.
ID:	120238   Click image for larger version
Name:	Table Leg Bracket.jpg
Old 01-27-2011, 04:22 PM   #56
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
I'm a little late to the game with these photos (referencing a few posts ago - hinged tableness). I have the hinge table (no U-thingee) and it's very slick. I lucked out and have the hinge and table. Not sure where to get them now.
Foam Mattress Pads Memory Foam Platform Beds & More seems to have good quality foam and have loads of info. Plus they'll custom build the foam for you for a nominal fee.
Hopefully these photos show you the table hinge in action, the shape of the back cushions, and how everything fits together. This is the original config (upgrade at water tank). The old blue cushion covers are long gone and the current ones are awaiting new upholstery.
Hope this helps. Good luck!
SpaceEgg is offline   Reply With Quote
Old 01-27-2011, 06:46 PM   #57
lucymcdog's Avatar
1965 24' Tradewind
Do you remember where you got your hinge for the fold-up leg?
Old 01-27-2011, 07:04 PM   #58
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It came off of the original fold down/up dohicky at the end of the original counter. It's the avacado green thing hanging above the old magazine rack. On the left end of the stove cabinet.
Old 01-27-2011, 09:15 PM   #59
lucymcdog's Avatar
1965 24' Tradewind
Really? I've got one of those that I think I'm going to do away with. Looks like a good use of it.
Thanks for all the great pictures you posted. My box that covers up the water tank in the front is sort of just like yours so I think I am going to stop my cushions at that point and do what Shari did and make a "filler" cushion for the space between the end of the squared off cushion and the curve of the front. That way I will be able to turn the cushions over.
Progress IS being made but not very fast.
Old 01-29-2011, 10:02 PM   #60
lucymcdog's Avatar
1965 24' Tradewind
Some progres...
Not much progress but at least we're having fun. Here's Lucy on the curbside bench.
Name:	curb bench lucy.jpg
dinette, table
looking for early Argosy 24' with twin and dinette turfclubroad Argosy Motorhomes 2 02-03-2011 02:56 AM
