Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 02-28-2015, 01:07 PM   #1
1959 22' Caravanner
tampa , Florida
Wiring issue with 1959 22' Caravaneer
We have a short in the wiring that goes to the porch light? Is there anyone who has had to fix an issue with the wiring? If so, please let us know. Thank you
gaylonlee200 is offline   Reply With Quote
Old 02-28-2015, 03:51 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
When you say you have a short. Are you blowing the fuse? If so, when does it blow? When you attempt to turn the light on?
What exactly are the symptoms?
Old 03-01-2015, 09:18 AM   #3
1959 22' Caravanner
tampa , Florida
Thanks for jumping in.
We do not have the line fused yet. The 12v system is electrifying the trailer near the porch light. Positive line is contacting the frame somehow.
Do you have any idea what is causing this?
Old 03-01-2015, 12:05 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Please explain how you know the +12 volt is contacting the skin or frame.
If the line is not fused. What keeps it from melting or burning into the skin or frame. Is the problem causing arcing ?
If you are using a meter. What are you referencing it to when you read 12volts?
Cause could be the wire is chaffed or pinched. Or a part of the light fixture or switch is contacting the skin.
Old 03-01-2015, 04:02 PM   #5
1959 22' Caravanner
tampa , Florida
Ok, well here is what happened. Evidently, the porch light is a 110v, so we were baffled by this, since everything else has a 12v and 10v wiring system. Yes, it was arcing. So we pulled the skin back and the 110v wire had a bad connection. Fixed that, now we have to order the 110v socket from vintage trailer supply. So I am not completely sure, but i think this will fix the problem.
Thank you for you help. It is greatly and sincerely appreciated.
Old 03-02-2015, 12:05 PM   #6
1958 22' Caravanner
Plattsmouth , Nebraska
I replaced mine on the 1958 Caravanner with a dual battery 9 volt dual 16 LED light array which swivels 90 degrees
BigButtUgly is offline   Reply With Quote
Old 03-02-2015, 12:10 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It is a 100v light. Use an appliance bulb...it has two contacts like a 12v 1156.
Old 03-03-2015, 03:18 PM   #8
1958 22' Caravanner
AS to me is not AIRSTREAM it's Airstream Stupid. To this day most Airstream designs are AS. Why have a yard light drawing any kind of power from your rig when for $ 8.48 on eBay you can buy a motion sensor with a full on switch. Do as I, sensor will hang on a hook which is fastened with double stick tape. Pretty hard to tell it's not wired to a silent alarm. Comes on day or night. Might deter thieves. Full on not a good yard light (but original light on rig is no better} serves no purpose for lighting your picnic table as 4 D cell LED lanterns will do. I'll take mine off hook and go to CG bath rooms. I'll have a second one for roadside and I'll remove prior to OTR. Open your door , wave your hand, and your walkway is lighted. Return 4 hours later and when you get close enough you've got light. If it shines bright enough or far enough flip the back switch as you depart. Kids may mess with it however. Just spoke with Airstream dealer - no motion detector lights ever. Classic AS thinking. Dealer said it's an after market item. So drop $92,000 or more on a new one and then go somewhere to have it modified. AS
WIRELESS MOTION SENSOR LIGHT-10 SUPER BRIGHT LED NEW
Old 03-05-2015, 09:02 AM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
What does this have to do with the original question?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
1959 Airstream Tradewind :: 1959 Airstream Tradewind steveirving Airstream Registry Discussions 1 07-27-2021 06:15 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
1959 Airstream Travel Trailer 1959 Air Stream eBay Watch Airstreams on eBay 0 03-27-2010 01:01 AM
