Old 11-13-2017, 06:55 AM   #1
T Reno's Avatar
1991 29' Excella
Colorado , Colorado
Wiring Diagram
I have a 1991 29' Excella with an electrical issue and was wondering if anyone had a detailed wiring diagram. It started with the GFI breaker not holding before I went Elk hunting - I just left that breaker off and ended up during the trip with the batteries not charging off the generator & the furnace not igniting....
BTW I have the one page wiring diagram from the owners manual - just seeing if there is anything showing additional detail.
Thanks in advance.
T Reno is offline   Reply With Quote
Old 11-13-2017, 07:07 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Give Airstream a call. They emailed me diagrams/schematics for my old 66 Bambi II and 06 Safari.
MICHAEL
Old 11-13-2017, 08:08 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
You have 2 different problems. The furnace runs off 12 volts and unless the batteries went dead has no connection to the 120 volt AC issue.
First off disconnect everyting that runs on 120 volts AC, don't forget the frig and the convertor, and see if the GFI will reset. If not you either have a bad GFI or a dead short in the wiring. If the GFI hold plug one item at a time in and see if any trip the GFI.
As for the heater. If the fan comes on and after about 20 seconds the furnace does not light you may have air in the gas line. If it looks like that crack the gas line at the furnace till you smell gas. The orifice in the furnace is not big enough to purge air.
2004 Excursion 4x4
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 13 04-07-2021 02:20 PM
1975 P30 wiring diagram (as promised) ... Hayseed Airstream Motorhome Forums 1 11-22-2012 02:28 PM
Wiring Diagram 84 Excella 31ft dscluchfc Electrical - Systems, Generators, Batteries & Solar 2 01-03-2005 11:09 AM
wiring diagram 120v brunoffrance Electrical - Systems, Generators, Batteries & Solar 3 02-08-2003 01:41 AM
Wiring Diagram Needed 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 07-29-2002 12:21 PM
