03-03-2019, 07:42 AM
2021 33FB Classic
2019 30' Flying Cloud
Katy
Options to use "regular" extension cord when storing RV
I'm trying to plan ahead, and I wasn't able to find an answer by using the search function.
In a few weeks I'll be picking up my new Flying Cloud. With 50A service and dogbones to scale down to 30A and then to 15A, I know I will have the ability to use the 20A electrical at the storage garage I'm renting. However, I would rather not deal with the heft of the 50A cable that comes with my trailer. Is it possible to use a 10gauge 15A extension cord from trailer to electrical hookup without using the heavy cable? What does everyone else use?
Jayson
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
03-03-2019, 08:00 AM
Tampa
The issue will be the trailer connection.
I bought a second AC cord, which came with a 50 amp female and a 30 amp male. I got it mostly for the generator, but it's been more handy in the storage facility.
It weighs 1/4 of what the 50 amp cord does.
That reminds me, I ditched the Airstream 50 amp cord that coils like a bridge support cable in favor of one that is much easier to handle.
The right angle female takes the weight off the connector. It coils into a 18" loop easily.
03-03-2019, 08:04 AM
sacramento
I also did the same, pick them up on Amazon. I primarily use the 30 amp cord, no real need for the 50 unless in high heat or humidity climate's
03-03-2019, 08:47 AM
Sag Harbor
, New York
As long as you are not going to draw more than 15 amps of 120v you should be fine, assuming your #10 AWG cord is 50' or less IMO. We have a #12 50' cord on a 15 amp circuit to keep the batteries charged and run the fridge on 120v to get it cool before a trip. Your #10 is better IMO, and would probably permit longer than 50' per your amperage draw.
Clearly A/C and water heating is too much expect. Are there functions in your new 30' which will put you over 15 amps, like the Alde system and battery charger/converter? Guess you should add up the amperage of what you want to use, and let the total guide your cord selection.
Peter
03-03-2019, 08:58 AM
2018 30' Classic
Ivins
, Utah
To run converter and fridge while in storage I use this adapter plus a 15A power cable. Light weight, easy to handle.
https://www.etrailer.com/RV-Wiring/M...-1550DAVP.html
03-03-2019, 09:01 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
I use a 30 amp to 15 amp cord adapter that plugs into the trailer twist-lock connector and the end of my 10 gauge 100' extension cord.
Ray B.
03-03-2019, 10:26 AM
Sag Harbor
, New York
Originally Posted by steverino
. . . To run converter and fridge . . a 15A power cable . . .
How long is your cable and what is its AWG wire size please?
Peter
03-03-2019, 10:28 AM
Sag Harbor
, New York
Originally Posted by Adventure.AS
. . . my 10 gauge 100' extension cord.
What appliances and mech units do you run with this, and what are the total amps, please?
Peter
03-03-2019, 10:56 AM
2016 26' Flying Cloud
West linn
, Oregon
We store our airstream in a barn and use a 110v outlet and ordinary 10A cord for winter storage. Nothing’s running except the battery charger and furnace set at 40. It works fine. We also use a long 12A cord to run to the curb in front of our house the night before a trip to run the refrigerator. No problemo.
03-03-2019, 11:07 AM
2019 16' Sport
Alexandria
, Virginia
I use a shore power(at the marina where I store/use my AS 2019 Sport 16) 110v 20amp to 30amp adaptor connected to the dealer provided 25' 30 amp cable.Most managable weight wise. I also note that either 120v 15/20amp shore power and/or my Honda 2200eu Gen can easily energize and run my RV 11000 Btu AC ,with power to spare for other AC appliances.
Honda Watt Guide RV Air Conditioner
Sport 16 11000 BTU
Approximate Starting Wattage 1600 Approximate Running Wattage 1010
Other AS's 13500 BTU
Approximate Starting Wattage 2800 Approximate Running Wattage 1800
Ron1934. 1934 is my BD year.
03-03-2019, 11:30 AM
Lucedale
, Mississippi
I used a 50 amp to 15 amp cord adapter like the 30 amp one shown by Adverture.AS
just to run lights and small stuff when at home.
03-03-2019, 11:39 AM
2013 31' Classic
billings
, Montana
Jayson
yes...50 amp to 15 amp adapter...
03-03-2019, 11:41 AM
2018 25' International
Mound
[...] Is it possible to use a 10gauge 15A extension cord from trailer to electrical hookup without using the heavy cable? [...]
Technically you run a risk if any part of your trailer connection is rated less than the circuit breaker at your power source. If your breaker is 20A, all wiring should be rated for at least 20A.
I use this 20A to 30A adapter with my normal trailer cord when connecting to my home or any campground 20A circuit. It wasn't that easy to find - most dogbones are only rated for 15A. I haven't looked for a 20A to 50A adapter since my trailer only uses 30A.
03-03-2019, 12:13 PM
2015 30' Classic
Sherwood
, Oregon
50A to 15/20A dog bone connecting to a 50' 10 gauge (12 gauge would also work) to primarily run the four stage charger/converter when in storage or parked between trips. I run the hot water heater and refrigerator 48 hours prior to departure.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
03-03-2019, 12:31 PM
Niagara-on-the-Lake
, ON Canada
Peter
Fridge (2.7 amps) and converter/battery charger (8 amps). Of course the fridge and charger are not running 100% of the time.
Ray B.
03-03-2019, 01:26 PM
Sag Harbor
, New York
Thanks Ray, that is close to what I had figured for our FC20.
Peter
03-03-2019, 09:15 PM
1988 32' Excella
Robbinsville
, New Jersey
Why run the water heater for 48 hours before trip?
Mine heats up completely in under 30 minutes.
03-04-2019, 05:27 AM
2018 28' International
Fayetteville
, Georgia
I do the same at our storage yard. Runs the battery charger only. Also have a 50 amp RV outlet at home, so we can plug in and cool down before leaving on a trip.
brick
03-05-2019, 07:51 AM
2016 Interstate Lounge Ext
Prosper
I use this one as well...easy peezy.
03-07-2019, 08:29 PM
Long Island
, Long Island, NY
