07-27-2015, 12:18 PM
2023 23' International
Macon
, Georgia
50A to 30A Adapter
Does anyone make a 50A to 30A adapter that will fit the connection on my 2014 27FB International 50A unit? I would like to use my 30 A cable when I need to connect to a 30A outlet rather than using the heavy 50A cable.
07-27-2015, 12:50 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Try Furrion.
An adapter will not allow the use of L2 of your 50 amp service.... Your second air conditioning!
07-27-2015, 12:56 PM
2013 31' Classic
billings
, Montana
I found mine on amazon,
07-27-2015, 01:15 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The typical 50 to 30 adapters will provide power to both legs of the 50 amp tailer service. The user's responsibility is to ration power demand to not exceed 3600 watts. We are able to run the front air conditioner or the the rear air conditioner but not both when plugged into a 30 amp service. Each air conditioner is on a different leg than the other to balance the power draw when on 50 amp service.
07-27-2015, 06:05 PM
2016 27' Flying Cloud
Overland Park
, Kansas
I guess I'm living on the edge. Today it is record hot in Michigan Upper peninsula I'm at a spot with 30 amp running both a/c units. One on each leg and no breakers tripped yet. I have the refrigerator on gas and nothing else on. It's working and cooling down nicely. Hope I don't regret doing this. I also have a surge guard and it has not tripped either
Sandy
07-27-2015, 06:39 PM
Overland Adventurer
2009 34' Panamerica
Telluride
As long as the breakers don't trip and the compressors don't stall, you're fine!
Fwiw, my Penguin I units have a low voltage indicator and relay that inhibit the compressors from engaging.
I am in 100 degree heat on a 20 amp plug..... Nice and cool!
07-27-2015, 06:52 PM
Overland Park
, Kansas
Thanks. Yep. Me too. No low voltage or the surge protector would trip Nice and cool even while the gas burners are on
07-27-2015, 08:11 PM
1977 31' Excella 500
Berkeley Springs
, West Virginia
Camping World stocks them. Not a hard item to get.
See ya on the road,
- Jim
07-28-2015, 12:53 PM
2011 30' Flying Cloud
Arvada
More than what you need, but I found a 30 A cable that has the 50 A female connector. Since we use both AC units rarely, this lighter cable has really come in handy.
07-28-2015, 03:21 PM
Macon
, Georgia
Do you have the info on where to buy one of these? How do you make sure the female connector will fit the connection on the trailer?
07-28-2015, 03:23 PM
Macon
, Georgia
Do they make a 50A to 15A adapter so you can plug into 110v to charge batteries?
07-28-2015, 05:35 PM
2014 31' Classic
Apache Junction
07-28-2015, 06:55 PM
Macon
, Georgia
How do I know it will connect to the trailer?
07-28-2015, 07:30 PM
2015 28' Flying Cloud
Newtown
, Pennsylvania
If it says 50 amp female, it will fit.
Bruce
07-29-2015, 06:19 AM
Arvada
It is a stock 50 A female connecter - it will fit. I found it either at Camping World or Amazon.
07-29-2015, 06:22 AM
Arvada
Oh, we completed a two month, 11,000 trip in early June and I think we pulled the 50A cable out once.
07-29-2015, 06:24 AM
Arvada
It is on sale at Camping World. I think we paid $150.00 bucks for it
07-29-2015, 11:38 AM
Overland Park
, Kansas
07-29-2015, 02:09 PM
2013 31' Classic
billings
, Montana
I got mine in a blue winter cord for around 65 at amazon be sure to order 30 to 50 amp, I ordered moen the other way and had to send it back.
