Old 04-02-2012, 07:24 AM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
AC photos
Turns out the dual A/C has the "high capacity" (15,000 BTU/h) in front and 13,500 in back. I wasn't sure.
Anyway here are some photos.
Key points.
1) The use of a stainless steel band clamp to hold the reversing valve against the compressor is a complete hack. It comes loose with use. Retighten it every year as a periodic maintenance item.
2) Starting relay and cap are in the galvanized metal box curbside, under the shroud.
3) Shroud attaches with four sheet metal screws.
4) 15,000 BTU/h unit should be able to be identified by the presence of holes in the shroud, which are there to improve airflow through the condensor.
5) These are R-400 units designed for the higher line pressures that refrigerant requires.
6) There is already a crack in one of the shrouds on my trailer (after 2 years).
ID:	154809   Click image for larger version
ID:	154811   Click image for larger version
Old 04-02-2012, 07:30 AM   #2
dznf0g's Avatar
Oswego , Illinois
Just replace my shroud yesterday.....6 years from production date. It literally was as brittle and fragile as an egg shell. Noticed a crack showed up all on its own...ordered an Icon direct replacement. When I went topside, I steadied myself with my fingertips on the old shroud and poked 3 holes with my fingers. After removing the screws, I tossed it down into the grass and it shattered into hundred of small pieces!
-Rich-
2010 classic
WANTED: Front Dinette Photos InsideOut General Interior Topics 21 01-12-2007 03:09 PM
Photos from the St. Patricks Day Rally @ Desert Star Ranch Andy R Forum Rallies & Meet Ups 4 03-21-2005 11:07 PM
Store your photos @ AirstreamPhotos.com! Andy R Forum Admin, News and Member Account Info 63 09-06-2004 10:02 PM
Posts credit for Photos mwilleford Our Community 1 03-22-2002 06:02 AM
Attaching single photos Charcigar Forum Admin, News and Member Account Info 1 03-20-2002 08:09 PM
