Old 01-30-2011, 07:00 PM   #661
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by malconium View Post
Toastie,
The boomerang pattern is a great choice. Are you sure though that Formica stopped making it? I thought sure I saw the Formica samples for special orders at Home Depot not too long ago. I did actually buy some charcoal boomerang for my Airstream but I did order it through a counter top and flooring specialty shop and probably paid too much for it if indeed it can be ordered through Home Depot. I have ordered other Formica products through HD and the prices and delivery times were good.
Here are a couple of photos of it on my kitchen and bathroom counter tops. It is really cool stuff and the charcoal color was perfect for what I wanted.
Malcolm
Malcolm, your kitchen and bathroom look great. We are also going with the charcoal in the kitchen and the bathroom. Yes it is true, the only boomerang that you can buy is the charcoal, the other have been discontinued about 2 months ago.
toastie
toastie is offline   Reply With Quote
Old 01-31-2011, 02:56 AM   #662
Baltimore , Maryland
I think the stock will still be there a little while. Suggestion, go to the place Home Depot buys it.
Old 01-31-2011, 02:54 PM   #663
1973 31' Sovereign
Portland , Oregon
Images: 22
toastie
I guess it is a good thing that I picked the charcoal - just in case I end up wanting some more of it for something.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 01-31-2011, 04:31 PM   #664
toastie's Avatar
1955 22' Safari
I called a large local cabinet supplier today and found another sheet of Formica coral boomerang for the future. Some business are already asking $450 a sheet.....
toastie
Old 01-31-2011, 07:08 PM   #665
toastie's Avatar
1955 22' Safari
Finished the kitchen top tonight, almost 8' long, went with Formica CHARCOAL Boomerang Matte Finish #6942-58
toastie
Old 01-31-2011, 09:47 PM   #666
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Look there, Toastie has 1001 posts!!
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 02-01-2011, 03:33 PM   #667
Airdaddy's Avatar
1975 31' Sovereign
1969 27' Overlander
Wichita , Kansas
Water lines replacement
Hey Airstreamers long time, I need info if I can receive. I am, that is when the weather breaks replaceing the water system, lines and heating units both water and furnace. can anyone help me find the diagrams for my 1975 Sovereign 31 footer, bathroom curbside?
Airdaddy is offline   Reply With Quote
Old 02-01-2011, 04:37 PM   #668
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
I just got the manual for my 75. PM me and I can fax it to ya tomorrow.
Ed/Breadbug
Breadbug is offline   Reply With Quote
Old 02-02-2011, 10:50 AM   #669
Airdaddy's Avatar
1975 31' Sovereign
1969 27' Overlander
Wichita , Kansas
Ed: I don't have Fax where I am. Do you, or can you scan and email to dewingard@cox.net. Thank you for the reply and the assistance..
Old 02-04-2011, 06:14 PM   #670
toastie's Avatar
1955 22' Safari
For our wood finish we decided to go with antique black. The first coat is a pecan minwax polyshades, combines stain and polyurethane. Steel wool using liberon oil free steel wool, then another coat of the pecan, then steel wool again. Next we will use rust-oleum flat black paint, allowing this layer to dry completely. Using a fine sandpaper and sand the wood surface in random areas, will consider how cabinetry would age normally, the areas where years of hands opened the cabinet doors would show wear. Apply several coats of polyurethane to the protect the surface, done.
toastie
ID:	121402   Click image for larger version
Old 02-06-2011, 09:43 AM   #671
toastie's Avatar
1955 22' Safari
We are going with a pergo flooring, its called driftwood pine.............toastie
Old 02-06-2011, 10:13 AM   #672
Fyrzowt's Avatar
Images: 8
toastie
Love the updates!
As "on top of it" as you are, you probably have considered this, but I'll throw it out here anyway.
If you are using water based Poly, don't use steel wool. Any particles left behind will rust. It's hard to clean them all off.
AIR #15800
2000 Safari SS 25'
Old 02-06-2011, 11:58 AM   #673
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
I have seen that driftwood pine in several offices. It's a very nice looking floor.
ddstech is offline   Reply With Quote
Old 02-06-2011, 12:22 PM   #674
toastie's Avatar
1955 22' Safari
Originally Posted by Fyrzowt View Post
Love the updates!
Went with oil minwax polyshades, 2 coats, the steel that I used is liberon oil free steel wool http://www.rockler.com/product.cfm?page=1436
toastie
Old 02-06-2011, 01:13 PM   #675
Benjo's Avatar
1949 18' Trailwind
1963 19' Globetrotter
Huntsville , Alabama
Finally found some time to read through this thread. Wow! I learned a lot! Thanks for documenting the process and taking good shots of the work. Helps so much.
I have a question relating to post #481 about your roof vent. I have the shaft part but am missing the top vent piece. Where did you track yours down?
-benjo
Benjo is offline   Reply With Quote
Old 02-06-2011, 02:10 PM   #676
toastie's Avatar
1955 22' Safari
-benjo
Thanks, pure luck.........if you find 2 I'll take the other.............toastie
Old 02-07-2011, 05:06 PM   #677
toastie's Avatar
1955 22' Safari
Working on the dinette down in the basement today. Most of the dinette will be covered by the cushions............toastie
ID:	121766   Click image for larger version
Old 02-07-2011, 05:27 PM   #678
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Toastie... curious what thickness and what material you used for the dinette... 1/2"? Where'd you end up finding the edging? Outwater?
Looks fantastic!
Marc
Old 02-07-2011, 06:25 PM   #679
toastie's Avatar
1955 22' Safari
Looks fantastic!
Marc
Thanks Marc, the thickness is 3/4" finished plywood, the edging was bought off ebay. The company that makes the edging is MD Building
6CT 3/4" x 8' Alum Edging by MD Building Prod 67371 - eBay (item 260361762196 end time Mar-05-11 06:04:29 PST)
M-D Building Products
toastie
Old 02-27-2011, 12:12 PM   #680
toastie's Avatar
1955 22' Safari
Worked on cutting foam today. We bought from http://www.foamforyou.com/ . We went with 82" x 76" x 5" and made our own cuts. We went with there premium HD foam http://www.foamforyou.com/Foam_Specs.htm#Open . Very happy with the selection.
toastie
1955 safari, floor, redo
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Shell On Floor Replacement spitfyr Repairing/Replacing Floor &/or Frame 5 10-11-2007 05:03 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
