Jackson Center Frame Rust Mitigation
Hi Gang -
Our 2017 23FB International has quite a bit of rust on the exposed (visible) parts of the frame.
This is due to road salt. I drove it through some nasty weather to (ironically) have interior work performed in Jackson Center in February. A bad idea but here we are.
The newer trailers I believe don’t have fiberglass insulation under the floor so I expect the frame I can’t see is probably ok (disagree?).
The belly pan will eventually rust out but I consider those panels sacrificial protective parts to be replaced in due time.
We don’t have an ideal workspace to do what I want to do, which is grind,
prep., paint and then bedliner the exposed pieces of frame.
Has anyone had exposed frame rust mitigation (ie rust removal/repainting) done at JC? Experiences?
