Old 12-18-2011, 02:44 PM   #1
jonathan
1969 23' Safari
Homestead , Florida
Info Required - Frame Size
After reading about the take over of the Airstream company and the change in the frame size I now have a dilema,
there are 2 trailers I am interested to buy 1. 1973 25' Land yacht, 2. 1975 25' Land yacht, both the same price both similar condition,
Can anyone advise
Many thanks Jonathan.
jonnyregis is offline   Reply With Quote
Old 12-18-2011, 03:11 PM   #2
x
XXXX , XXXX
Jonathan both trailers are from the same era of company ownership and will be nearly exact in the production methods. The 75 will however have both a grey and black waste water tank and the 73 will only have a grey tank.
wasagachris is offline   Reply With Quote
Old 12-18-2011, 03:18 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think Wasagachris meant to say the '73 has black tank, no grey tank.
Old 12-18-2011, 03:26 PM   #4
x
XXXX , XXXX
yeah I did i guess I should engage the brain before I engage the keyboard.
Tech guys will call the an imput error. The problems lies in the interface between the keyboard and the user. Commonly known as a ID 10 TEE error(ID10T)
Old 12-18-2011, 04:58 PM   #5
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Go for the '75
Same era.
Same production methods.
Same length (25' is very sought after)
One has a gray water tank; the other does not.
Even though it is too small, that tiny tank makes a huge difference.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 12-18-2011, 05:21 PM   #6
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Can anyone advise
Welcome Jonathan!
I see you have been a forum member for several months, but this is your first post.
My advice, since you asked, would be to find a local volunteer inspector to help you make the best choice. Newer does not necessarily mean better. Condition is everything!
If you would rather do this yourself, there is a helpful list of items that should be checked during an inspection. Though, if you are not familiar with these items, the list may not mean much to you. The list of inspectors and the list of items can be found here on the forum if you look around.
Alan
Old 12-18-2011, 05:53 PM   #7
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Beatrice Foods almost trashed AS in the seventies and made mostly crappy coaches. I would be looking towards a later model (late seventies through the eighties) after the dust settled.
Mike Leary is offline   Reply With Quote
Old 12-18-2011, 06:25 PM   #8
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
You'll really rather have the black and the gray tanks. A lot of places won't let you run the gray water on the pavement or on the ground anymore. Tanks that don't leak are nice too.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 12-19-2011, 11:44 AM   #9
1975 29' Ambassador
Reno , Nevada
re: "Beatrice Foods almost trashed AS in the seventies and made mostly crappy coaches."
many times disproven, no substance for the allegation, yet some folks still can't handle the reality.
why?
When Airstream was bought by Beatrice and then by Thor it was still the Airstream company with the same employees, same designers, same facilities, producing the same product.
Old 12-19-2011, 11:58 AM   #10
A W Warn's Avatar
2000 25' Safari
I had no problems with 70's Airstreams
why?
From my experience, I agree with this. I have owned two 70's Excellas, one early and one late. Absolutely no problems with them related to design or manufacture! The only problems were created by misuse or lack of maintenance by PO's.
Alan
Old 12-19-2011, 01:43 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Airstream has designers??!!! They must be running photo copies of the designs from the 70's. I say that because I read a lot of comments from people who have AS's that are less than 5 years old and have the same problems I have with my 38 year old unit. Floor rot, windows leaking, vents leaking, rivets popping, cracks above the door and the list goes on.
When I think of the years this trailer has been made and the opportunities that have been missed in resolving many of these reoccurring problems. It makes me wonder what these designers do all day.
Don't get me wrong, I like the Argosy and expected to have "issues" with an older unit. But I would be a very unhappy camper if I payed out $60K or more and experienced the same issues.
All I can see is they have become heavier and along with it, expensive.
Old 12-19-2011, 02:40 PM   #12
Alumaholic's Avatar
Images: 36
Be Thankful for Beatrice Foods
why?
Beatrice Foods kept Airstream alive when the company was about to go under preserving the brand during those lean, Jimmy Carter years when gasoline was rationed and the age of American exceptionalism was over. During the Beatrice years we got a gray water holding tank and tambour cabinet doors, and 16" wheels were retained. Beatrice got us through the tough economic times essentially protecting the name and the product. This is all from memory, perhaps Fred Caldwell will see this thread and provide a more well-documented response.
Ken L
Old 12-20-2011, 07:00 AM   #13
1981 31' Excella II
New Market , Alabama
So when did Beatrice sell Airstream? My 81 has a beefed up frame compared to the 70 trailers. Mine has the double C-channel box beam contruction. I believe the 70's models had the single open C-channel beams. I have heard more frame problems in the new trailers than the old ones. The old ones are usually due to rot and rust.
Perry
Old 12-23-2011, 05:46 PM   #14
jonathan
1969 23' Safari
Homestead , Florida
Can anyone advise.
Many thanks for all your advice
Old 12-23-2011, 08:33 PM   #15
r carl's Avatar
Lin , Ne
Look what happened when AMF bought Harley Davidson... About the same time period. Similar results.
Old 12-23-2011, 08:46 PM   #16
RichardT's Avatar
Having owned a number of trailers, if they are the same price and condition I would always choose the 75 over the 73.
Can anyone advise.
RichardT is offline   Reply With Quote
Old 12-24-2011, 05:29 AM   #17
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you have searched here and on Google for information on Beatrice – frames, etc. you’ve found a lot of comment on those years. You’ll also have found different thoughts and what appear to be definitive statements. Some of those may or may not be true.
There are comments that Beatrice purchased Airstream in 1969 – another will say 1970. Beatrice actually purchased Airstream in the fall of 1967 and the final paperwork was filed with the State of Ohio on 12/5/1967. Beatrice renewed the Airstream trade name in 1972 and again in 1977. There are comments that it was sold in the late 70’s – another says 1980 which is actually what I see as correct. The State filings are not totally clear but would indicate the sale finalized in August 1980. By that time, the designs for the 1981 models would have been locked in.
Statements are made that the frame size was reduced from 5 or 4 inches to 3 inches. I’ve never seen one with a 3 inch frame – anyone out there have one? I looked at a 75 Ambassador last year for someone local – it didn’t have a 3 inch frame. The owner also had a 77 bare Ambassador frame there – it wasn’t 3 inch.
Other comments are out there that during the Beatrice years the trailers became heavier without the frame being beefed up. That’s not necessarily true. If you look at my Overlander it weighed 4,525 dry in 1969 and never went out of the 4500 range through 1977. The Ambassador on the other hand went from 4,715 in 1969 to 5,040 in 1977 but, by 1979, it was down to 4,630. The trailer you’re looking at weighed 4,340 dry in 1969. In 1973 it was 4,100 and in 1975 it was 4,110. It then dropped slightly in 1977 and 1979.
Several posters above indicate that is not a lot of difference between those two trailers and I agree. If you’re locked in on the frame issue – measure both where they exit to the bumper connection – is there any difference? The addition of the grey tank is a nice feature but, it could also be a problem. Did the prior owner(s) tow it long distance or over rough roads with a full black and grey tank – putting pressure on the frame. The frame condition is important and you’re wise to look into that.
Opinions are just that but mine is focus on overall condition, condition, condition. There’s probably not a dimes difference in these two units otherwise, and there’s an entire list of things that you should look at beyond the frame. Good luck with your choice.
How can a bent frame be fixed? Eagle & Bear Repairing/Replacing Floor &/or Frame 7 03-02-2012 11:48 AM
Can I just spray the frame with undercoating? robwok Repairing/Replacing Floor &/or Frame 5 12-01-2011 10:25 AM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
1965 Caravel Frame funhouse 1956 - 1965 Caravel 0 03-01-2011 09:12 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
