I purchased a '72
Sovereign a few months ago, and have demolished the interior in preparation for a shell-on total floor replacement. I have two questions to field to the experts in this community... (or really anyone who has an opinion)!
1. The front half of the floor was removed prior to my purchase and replaced with diamond plate aluminum shown in the pictures attached. Whoever removed the old floor did not join the floor with the c-channel and thus there are gaps between the floor and the shell. When putting in the new subfloor, what is the best way to 'pull the shell back in' --- i.e. line it up with the frame footprint before bolting it all together?
2. Never having done this before this is what I think I should be doing, please let me know if I've forgotten something (highly likely) all comments are helpful!
-Remove belly pan + insulation
-Stabilize c-channel with wood planks and jacks
-Cut flooring out (trying to preserve shape for cutting new floor) Best way to
do this??
-Frame care: remove rust w/ wire-wheel, replace any crossbeams needed,
apply a 'rust converter' (brand recommendations?), apply a sealant coat
(necessary?)
-Cut new floor and seal edges (marine plywood? Synthetic board
alternative?)
-Install floor, boards continuous from side to side. Bolt down through C-
channel
-Rejoice in new and extraordinary levels of stability!
Thanks for your time and assistance!
