Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1974 - 1979 Ambassador
Old 05-07-2019, 05:52 PM   #1
Charleston , South Carolina
Dry weight - 1979 28' Ambassador
Hi Yall!
I am looking at a "29ft 1979 ambassador" (This is what it is listed as). The seller is saying the "original manual" states the dry weight as 7200lbs. I though that sounded like a lot. Everything I have looked at says the weight is 4700. What gives? This is my first trailer, so please tell me what I'm missing. I will be using a Sequoia at a TV (max weight 7200lbs).
Thanks!
carrieddean1 is offline   Reply With Quote
Old 05-07-2019, 09:23 PM   #2
SlvrTwinkie's Avatar
1976 29' Ambassador
Logansport , Indiana
7200# sounds more like the total weight of trailer and cargo. According to AS Spec sheet on their website, if it is a twin bed the dry(tare) weight is 4630 lbs(#). The 28' w/double bed has a tare weight of 4690#. Hitch weight for the tb version is 550# and the db version hitch weight is 575#. YOu need to look at the tongue(hitch) weight your TV is able to handle also. Hope this helps. FYI that model cost $16k new, just to give you an idea the deal you got.
SlvrTwinkie is offline   Reply With Quote
Old 05-07-2019, 09:29 PM   #3
1976 29' Ambassador
I have a '76 29' Ambassador, my gross(total) weight is 7100# tongue weight is 515# and tare weight is 4855# according the brochures from AS.
Old 05-08-2019, 08:49 AM   #4
Weight and Thanks!
Thanks yall! The manual says my Sequoia's tow capacity is 7400 and max tongue weight is 950. It sounds like it could handle it, correct?
Old 05-08-2019, 05:13 PM   #5
1976 29' Ambassador
Sounds like it can handle that trailer, but I would talk to the dealer to be on the safe side. That is if there is a dealer close to you.
Glad I could help. You can go to airstream.com then click on owners. once you do that click on document archives, select the year you want and it will bring up some of the old documents for your year of AS. They are PDF files. That is were I found what you needed for your 79 AS along with the info on my 76
To Dry or Not to Dry...that is the question 4riveteers Dehumidifiers & Ozone Generators 12 11-12-2019 08:32 AM
How Do You Blow Dry Hair while Dry Camping tburnand On The Road... 88 09-16-2018 03:29 PM
Dry weight Question Bob Thompson 1997 - 1999 Safari 6 11-09-2008 12:38 PM
Dry weight variances Moonshot On The Road... 1 09-11-2003 08:06 PM
