Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Buyer Guidelines
Old 10-22-2016, 01:41 PM   #1
2017 30' International
Lincolnwood , Illinois
Red face Towing with Ram Eco-diesel
I am seeking info concerning the capability of the Ram 1500 eco-dieasel
with regards to towing, mpg while towing, and stabliity( how safe do you feel)
as a TV. If you are using this vehicle to tow an AS 25 ft or larger, any input you can provide would be deeply appreciated.
Milo1952 is offline   Reply With Quote
Old 10-22-2016, 02:34 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Milo, refer to your other thread "Tow Vehicle Recommendations" for some updated reports of those who use the EcoDiesel (and some who don't).
Doug and Cheryl
Old 10-22-2016, 02:38 PM   #3
1991 25' Excella
Stanfield , Oregon
I love mine it tows my 25 ft execcla great and gets 14-16 mpg while doing it.
SpletKay06 is offline   Reply With Quote
Old 10-22-2016, 03:24 PM   #4
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I recently traded for a Nissan Titan/Cummins, but while I had my ecodiesel towing a 25' FC it did an exceptional job in just about every terrain & temp. This past summer I towed over 10k miles cross country & got 16.2 mpg overall. The bad news is on 6&7% grades it usually started to heat up unless I slowed to around 45mph, however that was manageable. Payload was the big negative as my truck was the Laramie Limited with slightly over 800 pounds payload. Going cross country I was over limit but always cautious & concerned and the air bag suspension was a big help.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 10-22-2016, 03:25 PM   #5
dkottum's Avatar
You asked about mpg and how safe we feel.
We expect to see 15-17 mpg towing in normal conditions at 65 mph. If we reduced the speed to the 55-60 mph range I am certain we would often see 20 mpg. When not towing on the highway we expect 27-30 mpg at 65 mph.
Some years ago we had some concerns about stability with our Ram 1500 Reg Cab 120" wheelbase pickup. When semi's passed, or their were strong, gusting crosswinds we would feel pushed to the side. Never any sway oscillations. We installed a ProPride hitch on the truck, now use it on our EcoDiesel and would not tow a bumper-pull travel trailer without it.
Our truck/Airstream is absolutely rock-solid, semi's and sidewinds are nothing, traveling down uneven, rough, narrow secondary roads meeting trucks has no drama at all. Absolute confidence, the truck handles at least as nice as when without the Airstream attached. It is a very relaxing ride.
Safety is also about proper loading and load balancing in the truck and trailer. We are very careful about it, and after 50 years of camping and lots of travel we have learned how to do it (for us).
We do not carry excessive gear or supplies about the country, we load our Airstream with heavy gear toward the middle and light gear at the ends. The ProPride hitch is heavy as hitches go but it is also longer creating a longer lever from receiver to trailer axles; our fully loaded Airstream and hitch is not light but adds only 820 lbs to the truck's weight after weight distribution hitch lift is applied.
We load our EcoDiesel fairly light, heavy gear in front of the rear axle to lighten the task of the weight distribution hitch and weight on our rear axle. The weight distribution hitch evens the load on the truck's front and rear axles wishing 20 lbs of each other, and we are careful to not overload them (axle ratings on the door placard are 3900 lbs each). We then go to the CAT scale to verify this and ensure our loaded truck and trailer are within the Gross Combined Weight Rating for the truck, as that is the weight our rig can easily handle based on our own experience with Ram 1500's the past five years.
We don't set speed records up and down steep mountain grades, we hold the speed to not abuse our truck on the way up, and well onto the safe side on the way down, which is varied depending on road, weather, and traffic conditions.
We intentionally chose this truck for it's soft suspension, a better ride for us and our Airstream. We have not been on the "my Airstream is falling apart" threads with grievances, and we feel relaxed after several days' driving. Those contribute to safety as well. Our second coil spring Ram 1500, it is a great truck to drive at home and when we reach various travel destinations whole on our six month trips.
Doug and Cheryl
Old 10-23-2016, 11:54 AM   #6
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
"We expect to see 15-17 mpg towing in normal conditions at 65 mph. If we reduced the speed to the 55-60 mph range I am certain we would often see 20 mpg. When not towing on the highway we expect 27-30 mpg at 65 mph."
________________________
As a comparison, towing a FC 27 FB at 62-65 mph with a 2015 Ram 2500 diesel, I get 13-14 & without the trailer I get 20-22.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
Rgentum is offline   Reply With Quote
Old 10-23-2016, 12:28 PM   #7
dkottum's Avatar
Thanks Richard. Your mpg figures are very, very close to what we got with our Ram 1500 Hemi gas 6-spd 3.55 axles, if that would help someone. These are all decent mpg figures, the new pickups are good compared to some years ago.
Comparing your large diesel with our small diesel, it appears the small diesel is working closer to maximum power when towing, therefore the disparity between towing and solo figures of the two trucks. I don't think either one of us will wear our engines out towing an Airstream recreationally, probably not the gas Hemi either.
Doug and Cheryl
Old 10-23-2016, 07:40 PM   #8
2019 25' Flying Cloud
Greeneville , Tennessee
We love ours, a 2016 Ram EcoDiesel. We pull a 30' Excella, no problems. Flat land mileage is about 15.5 mpg, east TN mountains we get 12.5 to 13.8. Empty on interstate at interstate speed we do better than 30 mpg. So far, so good.
jimfa440 is offline   Reply With Quote
Old 08-21-2018, 03:59 PM   #9
Nokomis , Florida
I’m from Venice also and just learning about this. Would love to talk with you about this.
Vfossil is offline   Reply With Quote
Ram Eco diesel vs. F-150 3.5 Eco-boost Vagante Towing, Tow Vehicles & Hitches 43 06-25-2015 03:16 PM
New Ram Eco-Diesel Making Owners Sick! TheDuke Tow Vehicles 32 03-08-2015 11:43 PM
2014 Ram 1500 Eco Diesel RamblinManGa Tow Vehicles 2 02-11-2014 10:43 PM
