02-12-2010, 07:36 AM
1989 25' Excella
1989 34.5' Airstream 345
Hobe Sound
Welding repairs
Does anyone have any info as to the possiblity of damage to the electronics and or batteries if you have any heliarc welding done to external parts of tne coach? I need to have a repair done to the screen door hinge, and the welder cautioned me to disconnect batteries before proceeding. Even with batteries disconnected, what are the possibilites of damage to chargers/univolt or other equipment? I had my old 66 tradewind worked on many years ago without any problem, even without disconnecting, but there are many more things to get destroyed on my 345. To get the door off is a real pain and I would prefere not to unbolt the door hinges as I have been there fixing the bolts ( annother real pain)! Again thanks in advance for any info!
02-12-2010, 07:39 AM
Corona
Disconnecting the batteries, is a safety margin, just in case.
As long as the coach is not plugged into a source of electricity, the univolt will be fine, along with everything else.
ANDY
02-12-2010, 07:46 AM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Also, turn off the the propane at the bottles and drain the lines of stored propane by turning on a stovetop burner after turning off the propane at the valve(s). Let the flame go completely out and then turn it off.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
02-12-2010, 08:19 AM
More than one rivet loose
Los Alamos
, New Mexico
All depends on where he places the ground cable. The path of the current will be from the "torch" to the ground cable. If it's close, it should not be a problem. If it is far there will be a bigger antenna for the magnetic field.
Michelle TAC MT-0
Sarah, Snowball
02-12-2010, 08:28 AM
To minimize any gap arcing across a hinge I would suggest having him/her attach the ground lead to the part being welded.
Does anyone know the material alloy?
Best of luck,
Kevin
William C. Swinney
02-12-2010, 08:32 AM
Los Alamos
, New Mexico
Best of luck,
Kevin
It may be 2024, which is not weldable. Too many alloys. Didn't think of that the first time.
Michelle TAC MT-0
Sarah, Snowball
02-12-2010, 08:35 AM
Corona
Michelle.
I do not know what the alloy of the hinge is, but I do know that it's not 2024.
02-12-2010, 09:07 AM
1968 28' Ambassador
Cedaredge
I have done some welding on my door frame with my neighbors heliarc and had no problems.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
frame welding
RedBlur |
Repairing/Replacing Floor &/or Frame |
6 |
05-25-2008 02:31 PM |
welding the frames
Frank's Trailer Works |
Windows & Screens |
3 |
11-03-2007 09:07 PM |
Plastic Welding with PS 30
ALANSD |
Cabinets, Counter Tops & Furnishings |
12 |
01-21-2007 09:28 PM |
welding over/around POR15
pinkflamingoes |
7 |
03-06-2005 07:50 AM |
Solvent welding
dmadam |
Upholstery, Blinds, Walls & Interior Finishes |
1 |
05-14-2004 01:04 PM |
