05-02-2016, 09:48 PM
#201
Foothill Ranch
Look at thread "Clearance Clearance lights".
05-03-2016, 04:49 PM
#202
Newbie -- 1981 280 MoHo
1981 28' Airstream 280
Minneapolis/St. Paul
Thanks guys. I ordered one through VintageTrailerSupply.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
05-03-2016, 05:23 PM
#203
Ok, today they finally finished all the tons of tuneups under the proverbial hood.
The brand new radiator is installed and good to go. I'll get specific part and company info on the radiator when I pick up my 280 tomorrow and I'll post it here.
Next stop to get my set of new tires installed.
So far so good for staying on schedule to make it to Penn Wood at all costs (literally).
My airstream will be mostly a silver tent on wheels during the Penn Wood trip because I won't have had time to test (or fix if needed) any of the inside appliances or plumbing beforehand, but at least it can (hopefully) mechanically make it to the rally.
I hope Penn Wood has a bathroom and shower for me to use while I'm there. Hehe!
05-03-2016, 07:15 PM
#204
Dazed and Confused
Hillsburgh
, Ontario
Tap
No worries mate, all of us will have fresh water and a BBQ you can use. I always shower at the campground as the shower in my 310 doesn't really fit my 6'3" frame. Just go out and get an electric cooler if you're unsure about your fridge. If you haven't got your propane system checked yet I would buy a ceramic heater for heat.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
05-03-2016, 07:49 PM
#205
Thanks Tony, that all sounds great.
I'm also going to bring a few gallon jugs of fresh water.
05-03-2016, 08:15 PM
#206
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Tap, I suspect with the gear heads, spare parts, and knowledge base attending the Get Together any issue you have going into the weekend will be fixed before you leave!
I am a little like Tony, the on-board wetroom is for when no other option is available and typically use the campsite facilities. If all else fails I hear Brad has a hotel room nearby!
05-04-2016, 01:00 PM
#207
Very cool.
I can't wait to meet all of you guys.
05-04-2016, 01:02 PM
#208
05-04-2016, 01:53 PM
#209
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Yes Tap, there is a square plastic panel that slides out of the way to give access to the lock if opening from inside.
They are available from the online retailers or Airstream but come in a couple of different sizes so you need to be careful to get the right in.
05-04-2016, 01:59 PM
#210
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Must be sunny where he is ......
05-04-2016, 03:08 PM
#211
Tap's 1981 280 Motorhome (Purchased January 2016)
It's finally nice out in Minnesota!!!
Friday 86°!!!!
05-04-2016, 03:10 PM
#212
The square hole measures 8" tall by 6" wide.
05-04-2016, 03:13 PM
#213
Looks like this is what I need and then I'll have to trim it slightly.
http://www.vintagetrailersupply.com/...p/vts-1492.htm
05-04-2016, 04:45 PM
#214
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Originally Posted by Tap
Sure looks like it Tap
05-04-2016, 05:52 PM
#215
Is there anything that can be done for rust rings on the laminate counter and rust on the cooktop cover?
05-04-2016, 06:19 PM
#216
Richmond
, Kentucky
Elbow grease?!
1975 24' Argosy Motor Home
05-06-2016, 12:42 PM
#217
Guys, my 210 is now running well, but it is *SUPER* loud when I accelerate.
It's quiet enough when it's just idling, but whenever I push down on the gas peddle it sounds just like a Harley Davidson convention.
Super loud inside and outside. It sounds like it's right up front. That can't be normal. We wouldn't even be able to talk in the RV.
So what is that?
My guess is the exhaust must not be connected or has a big hole, so it isn't being muffled by the muffler?
Do you think that's it?
05-06-2016, 12:52 PM
#218
2013 30' Classic
Greenwood
, Mississippi
Cracked/broken exhaust manifold or do-nut gasket-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
05-06-2016, 01:05 PM
#219
1982 31' Airstream 310
champaign
Lift your engine cover and see if you can isolate where the leak is. That is, if you think its coming from up front. If not there, youre going to have to get underneath and inspect your exhaust.
05-06-2016, 02:03 PM
#220
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
Both the exhaust manifold to head connection and the back of the headers connection to the tail pipe are suspect and common leak points.
Hopefully the parts are OK. So you can get gaskets and just bolt things back together.
There is some question about the use of gaskets between the manifold and the heads. I just installed gaskets there and am happy with the results.
Between those and new donut gaskets at the collector pipe the noise as well as fumes in the cabin are MUCH MUCH IMPROVED!
It's nice that there is so much clearance under these coaches that its possible to crawl around and check out these things with out a lot of jacking etc.
CHEERS Richard
