Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 02-22-2012, 06:50 PM   #1
SteelyDan's Avatar
1982 31' Airstream 310
Portland , Oregon
Replacement panel compatibility
My 310 has some dented panels. When looking for replacements, what panels are compatible? From my understanding, from the cab back its a standard AS shell of the period. I assume the cab's panels are interchangeable with all the classic style bodies, including the Argosy? Thanks for the help!
SteelyDan is offline   Reply With Quote
Old 02-22-2012, 07:47 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Dan, post some pix of your dented panels. I'm sure that someone here will be able to help.
Thanks, Derek
Old 02-22-2012, 07:55 PM   #3
Retired.
. , At Large
You can use new panels you can get from any Airstream dealer, and are the same between trailers and motor homes. The ones you would want are for the "narrow body", or 96" wide coaches, some of the panels for the 102" wide coaches may not fit right. Be aware, however, the new panels will have a different "finish" than what's on your motor home now.
Old 02-22-2012, 08:06 PM   #4
SteelyDan's Avatar
Portland , Oregon
I'll post pictures tomorrow. Thanks for the Help Terry! Do you think you'd be able to tell the difference between old and new panels once they are polished?
Old 02-22-2012, 10:34 PM   #5
crazeevw's Avatar
Dan, believe that the difference in panels started in the late 70's, early 80's, so those of us with motorhomes will more than likely get the same result in polishing as the newer AS trailers. Find Keyair's thread (newbie just bought an '84 345 motorhome). He's done quite a bit of polishing on his motorhome and it looks GREAT!
Old 02-23-2012, 03:49 PM   #6
SteelyDan's Avatar
Portland , Oregon
Here are the panels in question.
ID:	151792   Click image for larger version
ID:	151794   Click image for larger version
Old 02-23-2012, 03:49 PM   #7
SteelyDan's Avatar
Portland , Oregon
The panel in the rear.
ID:	151796   Click image for larger version
Old 02-23-2012, 05:11 PM   #8
Retired.
. , At Large
Those are all standard Airstream panels. If the person doing the polishing knows what he's doing, the panels will polish nicely. There are a couple extra steps to polishing the "new" panels, to make them shine.
Old 02-23-2012, 10:36 PM   #9
Silverton , Colorado
Rear panels will pose a challenge, as I believe they will probably have to be custom shaped and cut, and extreme care taken for around the rear(curved) windows...dig deep into yer pockets and eat lightly...or just get out and drive it...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 02-23-2012, 11:28 PM   #10
SteelyDan's Avatar
Portland , Oregon
We're actually thinking about deleting the rear window all together, for more bedroom privacy and insulation. I've noticed a few models of classic MHs with a single window in back. I assume the single window style panels would also fit?
Old 02-23-2012, 11:34 PM   #11
SteelyDan's Avatar
Portland , Oregon
I'm also assuming there isn't any way to repair the existing panels?
Old 02-24-2012, 03:06 AM   #12
crazeevw's Avatar
Dan, the only way I can see repairing the existing panels would be to remove the inner skin and 'roll' the outer skin back into place. Of course this could present problems as well. Seems as if I've read you have to be very careful doing something like I'm describing. Using a heat source on the aluminum while trying to roll out the dents should be done carefully. Try to do some searches about dent repair, there should be plenty on the forum.
Thanks, Derek
Old 02-24-2012, 08:40 AM   #13
Dan, if you're going to remove the curved rear windows, may I be the first to request them??? mike
Michael & Tracy
1989 345 Motorhome
Old 02-24-2012, 01:39 PM   #14
My '84 345 is an oddball, custom order, and has the single rear window.
If I were you I would leave that mod well alone.
Way too much trouble, for little gain!
It looks like the center window is different too...
Take a look at this thread in the Skins section for an idea of what can be done and it will make you feel better...
http://www.airforums.com/forums/f381...res-64383.html
The dents you have in the rear, are not too bad, and if they bother you, I would put the work into pushing them from the inside... I bet a buck, you can get them looking pretty good for way less work than replacing.
The cracks and damage to your ABS panels can be fixed with a mixture of MEK and ABS mixed to a slurry, and I can guide you how to do that.
The front creases if I am correct maybe accessable from inside the wheel housing, and if they are a good panel guy could do wonders on them.
Personally, I would not replace any of those those panels....
My rear RH upper was damaged and someone drilled holes and tried to slide-hammer it out... needless to say it cant be rescued...
Old 02-25-2012, 07:10 PM   #15
Alumnati
1986 34.5' Airstream 345
Fredericksburg , Texas
I've done a lot of metal work in my time, building and restoring custom cars. Aluminum is difficult because it is so soft. Any hammering or hammer and dolly work will stretch the metal. A roller will work but it will never be perfect. Use a contoured roller. A straight roller, even with rounded ends will make new marks. I don't know where you would get a roller. Maybe someone else can chime in here. You need to remove the inner panels either way so try a roller. If you don't like the results, then replace the panels.
vonprum is offline   Reply With Quote
Old 02-25-2012, 07:21 PM   #16
I agree, aluminum is tougher to rework.
As you said, its worth a shot to roller them.
There is a current and ongoing discussion about rollers in the skin section.
Old 02-25-2012, 07:55 PM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
For your safety?
Hi, removing the rear windows completely would also remove your escape hatch too, wouldn't it?
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Black water tank replacement '74 Land Yacht rear bath bhutch74ly Plumbing - Systems & Fixtures 27 06-23-2016 09:56 AM
Floor replacement in a 1972 31' Airstream papajoes2 Repairing/Replacing Floor &/or Frame 5 04-03-2012 02:53 PM
1969 Ambassador Axle Replacement Silverflames Axles 13 03-04-2012 07:28 AM
Replacement panel compatibility SteelyDan Classic Motorhomes 16 02-25-2012 07:55 PM
Tongue jack replacement snkrichards Towing, Tow Vehicles & Hitches 5 02-19-2012 06:04 PM
