01-26-2019, 05:09 PM
#1801
Richmond
, Kentucky
Originally Posted by dadstoy
I need some recommendations on water pressure regulators. I'm using the type that are external and screw onto the water hose.
We have very high pressure here and the one I have (see pic) restricts the water to the point that I don't get any pressure at the galley sink. I've read reviews in the past that have said "most" of these are no good. Any out there that actually work?
Looking forward to hearing what others use. I'm going to need to buy one myself one of these days.
1975 24' Argosy Motor Home
01-26-2019, 07:20 PM
#1802
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Makes no sense that you dont get pressure at the galley sink? Do you get a burst of pressure when you first open it and then it tapers down?
I have used those for many years and they always work well for me. You may have an unrelated issue somewhere in the line that only gets overcome with higher pressure.
Airstream Motorhomes (and trailers) have a built water pressure regulator. Assuming it is working, have you tried to connect the water supply without the above mentioned inline regulator? You may have some restriction in the onboard regulator.
I once connected my waterhose and only got a trickle of water inside.
I finally disconnected it again and discovered that many ants must have been in the hose and they plugged up the little water inlet screen.
AIR #13
01-26-2019, 07:46 PM
#1803
Dazed and Confused
Hillsburgh
, Ontario
When I first bought my coach I made the mistake of buying a water regulator; pretty expensive one too, with an oil filled pressure gauge....
https://www.rvwaterfilterstore.com/Adj.htm
...then I replaced all my plumbing with PEX-A.
PEX-A is designed to take a burst pressure of 800 PSI. if you're planning on hooking up to a water line with pressures above that; I'm pretty sure your water hose will crap out first.
I don't run a pressure regulator.....I have one for sale though.....
Cheers
Sidekick Tony
01-26-2019, 09:17 PM
#1804
1974 27' Overlander
Baltimore
, Maryland
Cheers
Sidekick Tony
OK, so what's the pressure rating on all the other stuff that's hooked up to your plumbing? All the faucets, toilet, shower valve, water heater, water inlet, the water pump, any water filters you might have...
The point of failure from a transient high pressure event is typically an appliance or fixture, not the pipes themselves. Even with PEX-A pipe, a regulator is worthwhile protection.
01-26-2019, 10:33 PM
#1805
_
, _
Time for a glass of wine and a camp fire!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
01-27-2019, 12:17 PM
#1806
_
, _
I disconnected the regulator and the filter and pressure in galley and bath are good...actually too high. Hooked up filter and pressure was high. Hooked up "old" inline regulator and pressure was what it should be. So the new regulator is crap. When I recently bought a new filter and a few other items, I got the new regulator simply to change out the old one which I have had for many years.
While recently fixing my broken plumbing, I removed the internal regulator originally installed by AS. After all these years I had no idea whether it was working or not.
05-05-2019, 12:26 AM
#1807
_
, _
When I rounded the corner yesterday and glanced over at the MH and saw it leaning, I new I had some extra work ahead of me. I pulled the wheel and with the weight off the tire, it basically rebeaded itself. Tire was leaking at the valve stem.
05-05-2019, 06:33 AM
#1808
Richmond
, Kentucky
Dean, you got lucky on that one!
I know you have to rotate your coach from site to site every so often, so I was surprised to see where it appears the tire had sunk into the ground. Is that typical?
05-05-2019, 07:41 AM
#1809
1981 31' Excella II
New Market
, Alabama
My experience with those hose end regulators is that they are mainly a flow restrictor more than a pressure regulator. The Original Watts pressure regulator is a good unit and I believe they can be rebuilt. Don't trust any of them without a gauge on the low pressure side. Not uncommon for pressure to creep up when there is no flow. Another option is to put in a relief valve that will dump pressure overboard if it gets above a certain value. This would be down stream of any regulator. Here is what I am using. https://www.amazon.com/Watts-0009257...s%2C193&sr=8-3
Perry
05-05-2019, 09:30 AM
#1810
_
, _
Thanks Perry. I'll check that one out!
Perry
05-05-2019, 09:43 AM
#1811
_
, _
I think I was lucky! We took the tire into town anyway since I didn't have any spare valve cores. It was nice to have my 1/2" 20volt impact with me to make the job easier. With the ruts and flat tire, I used the front hydraulic jack, a bottle jack and a low profile floor jack to raise the front end. It was a busy two days dealing with the flat tire, burned up electrical receptical on my friend's trailer and a slide out on that trailer that isn't working.
The ruts on that space were from the last time we switched spaces back in Feb (lots of rain this year). I basically "sunk in" backing the MH into that space back in Feb. Right now the ground is like concrete!
It hasn't been a relaxing weekend, but we did get a short ride in before the sun went down yesterday.
05-05-2019, 09:47 AM
#1812
_
, _
05-05-2019, 10:17 AM
#1813
_
, _
What should the wheels be torqued to? This is the first time I’ve taken a wheel off the MH myself.
05-06-2019, 08:18 AM
#1814
Dazed and Confused
Hillsburgh
, Ontario
175 ft/lbs
05-06-2019, 05:26 PM
#1815
Churubusco
, Indiana
Could have been worse!
05-07-2019, 04:35 AM
#1817
Richmond
, Kentucky
Wow! A Classic motorhome doubling as a farm tractor and plowing furrows
05-07-2019, 06:15 AM
#1818
Churubusco
, Indiana
Let's just say AAA is losing money on me
05-29-2019, 06:31 PM
#1819
_
, _
Now that is some plowing! What are you going to plant in those rows? I love corn being that I have Minnesota blood in me!
05-29-2019, 06:59 PM
#1820
_
, _
