10-19-2015, 06:25 AM
#81
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Looks great in the photos. If you ever chose to replace rather than repair, they are still available direct from Airstream at $110 each side. I got a pair from Airstream Supply drop shopped direct from Airstream about 6 weeks ago and have them as a custom back-up if Brad isn't able to get a mold off his Argosy valance.
10-20-2015, 06:02 AM
#82
1979 24' Airstream Excella 24
Tipp City
, Ohio
I wish I had known that before I spent all that time. I thought I
saw them somewhere priced at $450.. Clearly I should have replaced them. Oh well, it was good experience. I used the same technique for other ABS repairs and I am sure the skill will come in handy again sometime in the future.
By the way I like what you are trying to do with the Argosy specific front bumper.. Hope it works out for you and Brad.
10-20-2015, 06:24 AM
#83
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Some of the other vendors do sell FRP versions for $450 Greg, I am assuming they have gone through the 'take a mold, reproduce in FRP' route when the ABS ones weren't available (I can't think if another reason).
I also remember a post that many of the old ABS molds got destroyed and those that didn't Andy at Inland RV had obtained and was making them, so maybe they are making FRP reproductions from the ABS molds....who knows!
I do wish Airstream would publish a list of parts that are available, because several times I searched high and low for used parts only then to find they were still in production, but also in a couple of cases had assumed they were still available only to to find they weren't after starting a task.
I am all for repairing something that is repairable so more power to you for doing so!
10-21-2015, 06:41 PM
#84
Tipp City
, Ohio
Nice day,70 degrees, low humidity and calm winds. Not likely to see another day like this before winter. Not really ready but, today is the day. By the time I got it sanded masked and pre-cleaned it was nearly dark. No stopping now. Painted it with a trouble light in one hand and a paint gun in the other. No idea what it is going to look like. I guess I will know when the sun comes up tomorrow.
10-22-2015, 11:32 AM
#85
Richmond
, Kentucky
Suns up...
1975 24' Argosy Motor Home
10-24-2015, 08:52 PM
#86
Tipp City
, Ohio
Yea it is, and the nice days just keep coming, trying to take advantage of each and every one of them. Decide to take this opportunity to take care of a few more lose ends before the weather shuts me down for the winter.
The paint job turned out pretty good all things concidered. There was one spot that got missed and one run by a latch. A little more orange peel than I would like but overall I am pleased.
It would be a shame to put a nice new flag pole in this old rusty trailer hitch.
10-25-2015, 04:11 PM
#87
Richmond
, Kentucky
Interesting pattern of holes in the frame member. I haven't seen that on an Airstream chassis before.
Maybe Airstream was trying to save weight...
10-25-2015, 06:12 PM
#88
Tipp City
, Ohio
Yea, that's what I was thinking. Made a nice place for the mice to build a nest but, I don't think that's why they did it.
I like using POR-15 for rusty metal like this. Note to self ; buy it in quarts next time. Had to cut a hole in the lid to get it open. When it dries it gets really hard!
Went ahead and painted the front while I was at it.
Might as well paint the grill while I am at it. Does it ever end????
10-26-2015, 08:22 AM
#89
Richmond
, Kentucky
Greg, looking good
I've always used a product called Miracle Paint by Bill Hirsch. It has similar if not the same properties as POR-15. The difference might just be in the price, Miracle Paint seems to cost about $6 more per quart.
I plan on doing exactly what you've done with the exposed chassis areas, paint paint and more paint...!
11-02-2015, 06:59 PM
#90
Tipp City
, Ohio
Arggh! Now what?
When I took the grill apart to paint it, I found that the high beam inner headlight ring was all rusted out. I took it all apart and marked all the wires very carefully. When I put the grill back in and connected the head light wires they went haywire on me. When I put the head lights on they seem to work fine. When I hit the brights the lower bulb comes on as it should but, the upper bulb goes out completely. The other side seems to work fine (I never disconnected any of those wires). Any ideas ?
On a lighter note the new flag pole and flags came in this week. Super nice quality American made pole. Someday I hope to fly them someplace besides my back yard!
11-03-2015, 07:20 AM
#91
Richmond
, Kentucky
Greg,
Check your ground wires closely. I've seen odd things happen with headlights due to a bad ground.
That headlight bucket certainly was rusty. Good thing these rigs are made out of aluminum!
11-05-2015, 05:56 PM
#92
Tipp City
, Ohio
For a MH that spent (as far as I know) its whole life in Ohio there is very little rust on this MH. The inner headlight trim was a mess. Thru the magic of Google and a little persistence I found a new inner mounting ring at ClasicParts.com. At $24.95 it was the deal of the century. They also had the adjusting screws. 81-88 chevy pick-up seems to be the key cross-reference. They did not have the spring I need , I will keep looking.
11-05-2015, 06:19 PM
#93
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
So, there are 4 different ones? It looks like the one you needed was the cheapest and the others are double or triple?
AIR #13
11-06-2015, 02:30 PM
#94
Tipp City
, Ohio
When they shipped me the inner mounting ring they sent me a catalog with it. They also have an assembly for all four that includes the inner ring , the outer ring and the light bulb for $27.95. The part I received appears to be OEM. I suspect the assembly is imported,
Looks like they have the front turn signals as well, including the screws and the gaskets.
11-06-2015, 03:20 PM
#95
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
When I hit the brights the lower bulb comes on as it should but, the upper bulb goes out completely. The other side seems to work fine...
would love to hear what you find - ours does the same! on the list of fix-it to-do's....
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
11-07-2015, 04:39 AM
#96
Airstream Driver
1994 30' Excella
Austin
Thanks for the link and the info. Do you have the part number for the front turn signal. I found the side markers but not the turn signal.
AIR #13
11-07-2015, 06:00 AM
#97
Richmond
, Kentucky
I didn't see any link posted?!
11-07-2015, 06:19 AM
#98
Airstream Driver
1994 30' Excella
Austin
Link to the classicparts
H/L Body Mntg Ring-R/L-DHL-Classic Chevy Truck Parts
AIR #13
11-07-2015, 04:28 PM
#99
Tipp City
, Ohio
Got he headlights fixed!
I took the working side apart and checked the wires with a multimeter.
brown wire - low beam
black wire - ground
green wire - high beams
greenish yellow wire - high beam to upper bulb
My problem was the greenish yellow wire was loose in the wire nut. What genius thought it was a good idea to use a wire nut in a motor vehicle?!!
Now the turn signals won't work. ARGHH!!!! Flashers work fine just no turn signals, Here we go again.
11-07-2015, 05:22 PM
#100
Richmond
, Kentucky
That little gremlin sure is jumping from place to place isn't he
Do the flashers and turn signals use the same module? I could be wrong but for some reason I'm thinking they are separate.
