Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-21-2019, 11:56 AM   #1
1989 29' Airstream 290
Northants , Northamptonshire
City fill regulator
Hi every body
Can any one help me/point me in the right direction of where I can find a replacement city fill regulator for my 1989 290 le
Thanks in advance Ben
Wazley is offline   Reply With Quote
Old 10-21-2019, 12:06 PM   #2
1981 31' Excella II
New Market , Alabama
I have one of these at the house and in the trailer. I have found some of the cheaper ones leak up in pressure when there is no flow. Good idea to put a gauge on both sides of this regulator and watch the pressure on the low side with no water flowing. You can also install an RV that vents water overboard if the pressure gets too high.
https://www.amazon.com/Watts-0009257...1681018&sr=8-6
Old 10-21-2019, 12:17 PM   #3
Thank you very much I shall get one ordered
Proper City Water Fill, 30A inlet, etc. Placement? worldinchaos General Repair Forum 6 05-14-2020 05:58 PM
Fill Tank from City Water Hook-up using clever Electric Solenoid Valve Setup? trekerboy Electrical - Systems, Generators, Batteries & Solar 16 01-15-2015 10:57 AM
drip at city water fill pvmsteve Land Yacht/Legacy Motorhomes 10 06-10-2013 04:59 AM
Need advice on removing City Water Fill on 1994 Limit Don McKelvay Fresh Water Systems 2 11-01-2011 10:47 PM
Fresh Water fill from City Inlet question Distantdrummer Fresh Water Systems 7 07-15-2010 05:38 PM
