Old 10-18-2019, 07:59 AM   #1
Airstream Newbie
rv4007's Avatar
1978 31' Sovereign
Covington , Louisiana
Location of AC Drain on 350LE?
Does anyone know where the AC drain exits on a 350 LE?. I have two rooftop A/Cís that are both spewing water, so I know the drain is plugged, but I just canít find it.
rv4007 is offline   Reply With Quote
Old 10-20-2019, 08:11 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Rubber tubes are all that show.
Front is in the left front wheel well.
Rear is in left rear wheel well.
Blow air up them, but you will be lucky if they are only plugged up.
I have remounted both of mine due cracked drain pans. I replaced the pans with the new drain cups from Dometic.
https://www.vintagetrailersupply.com...-p/vts-079.htm
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
91 350le waterpump not working jerry220ver Water Heaters, Filters & Pumps 4 11-22-2006 04:41 PM
Looking at a 1991 350LE dssauburn Trailer Values 24 11-19-2006 07:32 PM
