12-09-2019, 11:09 AM
#441
Richmond
, Kentucky
Yuki,
Do you plan on carrying a lot of extra weight in the Argosy?!
I installed air bags like those on a 1976 Coachmen motorhome to fix a leaning problem. They worked out quite well.
Looking at the pictures from underneath is like deja vu for me!
1975 24' Argosy Motor Home
12-10-2019, 06:49 PM
#442
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by bkahler
Yuki,
Brad,
No, I don't. I would rather not increase extra weight in the Argosy.
But it has long rear overhang also water tanks sit on there.
I think the rear end was leaning a little bit when it's full loaded. I'm not sure, my memory is vague..
And I want to load a minibike on a hitch carrier some day.
To tell the truth, it's just curiosity to install air bags in the Argosy!
12-11-2019, 09:44 AM
#443
Richmond
, Kentucky
Originally Posted by GREEN ARGOSY
Brad,
I would not be surprised if it was leaning. Mine had a lean to it as well which is why I ended up buying new springs. I'm hoping that corrects the problem.
That should be no problem at all.
That means you have so much money you don't know what to do with it so you spend it on the Argosy
12-11-2019, 07:56 PM
#444
1977 20' Argosy 20
Matsubushi
, Saitama
Replacing springs should be better solution. Probably mine is also deteriorating.
However, I guess leaf springs are so heavy, if I buy it need to pay much international shipping cost..
So I'm not going to replace it at this point.
I wish it were so, but unfortunately I'm not!!
I've been spending most of my salary on the Argosy. That's because I caught a disease, I'm not alcoholic, but absolutely I'm "Argoholic"!!
12-12-2019, 11:42 AM
#445
Richmond
, Kentucky
Replacing the springs was a really nasty job. I'm glad I did it but I do NOT want to do it again!
If you do want to replace your springs you could just as easily take the springs to a shop that does suspension repair and have the re-arch the springs for a lot less money.
Argoholic, that's a new one but you're right, it's a disease
12-13-2019, 03:39 AM
#446
1977 20' Argosy 20
Matsubushi
, Saitama
Brad,
What's the hardest or most troublesome to do things of replacing the spring?
I'm thinking to replace spring bushings.
I haven't heard the re-arch spring method before.
Anyway, I have only replacing and reassembling leaf spring experience in my Datsun, that's for lowering vehicle height.
The reassembling work meant dismantling the springs then assembling middle of springs upside-down. It's a cheap trick, made worse ride quality so I replaced to lowered springs instead of that.
12-22-2019, 04:52 AM
#447
1977 20' Argosy 20
Matsubushi
, Saitama
I made tailpipes today.
It looks like patchwork.
I used four of 45 degree bend pipes, one of 90 degree bend pipe and a reducer adapter (2.5" to 2.25") on each side.
The exhaust pipe fabrication is almost done.
12-24-2019, 08:25 AM
#448
Richmond
, Kentucky
Are you planning on welding the exhaust pipes once you're got everything fitted properly?
12-25-2019, 06:26 AM
#449
1977 20' Argosy 20
Matsubushi
, Saitama
I've welded some part of the exhaust pipes already.
I'm going to use clamps in the other part of connection, because it would be easy detaching the pipes when maintenance.
However, I need to redo welding in several parts.
My welding skill is not that good!
12-25-2019, 06:53 AM
#450
Richmond
, Kentucky
Welding is nothing more than practice practice practice
For the joints that you're not going to weld you might consider using Band Clamps. They don't distort the metal which makes it a lot easier to separate the pipes when you need to take things apart.
12-31-2019, 02:37 AM
#451
1977 20' Argosy 20
Matsubushi
, Saitama
Yeah, I need more practice on welding!
These are patchwork tailpipes.
I bought these clamps already.
But some lap joint clamps appear to be smaller than the 2.5" pipes' OD..
The final Argosy work in 2019 is removal an engine and trans, I hope this is the last time.
I'm going to make a bulkhead (between the engine and trans) and some frame for floors, then paint all of the frame.
I should move the argosy from a garage to outside in the next year.
I must do it!
01-05-2020, 06:02 PM
#452
1979 24' Airstream Excella 24
Tipp City
, Ohio
Yuki,
I have been following your thread all along, You are doing a great job. At times it seems overwhelming but, if you keep plugging away one day you will realize your dream of driving down the road. Trust me when I say its worth it. There is no feeling in the world like driving one of these old MH's down the road.
If you have not heard of POR-15 you should check it out. I used it to paint my frame and I am a believer , the stuff is amazing.
01-07-2020, 08:00 AM
#453
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by Gregsch
Yuki,
Thank you for your encouragement.
I hope to drive the Argosy again in the near future!
I'm a POR-15 believer too.
I've used it for my cars and motorcycles.
POR-15 Rust Preventive is popular with car geeks who love do restoration work, we can get it easily over here.
But I know it's weak to UV, it needs top coating if paint it where to exposed to sunlight.
I'm going to paint POR-15 Rust Preventive to a frame and hidden places.
And I bought POR-15 Top Coat from the USA.
I can't get that in Japanese market.. (Its shipping cost is pricey, but I was not able to choose other options..)
I'm going to paint the Top Coat to a chassis.
I painted it to some brackets and a gas tank recently.
I'll post my work report later.
Stay tuned! Thank you
01-12-2020, 05:07 AM
#454
1977 20' Argosy 20
Matsubushi
, Saitama
I'm tackling a fuel tank modification.
The first, install an electric pump in a tank, then paint it.
Here is my fuel tank.
I removed a gauge sender unit, it's not bad condition. I'll reuse that.
There's a little bit debris in the tank but not critical damages.
I'm going to use this unit with Atomic EFI.
So I need to make big hole on the top of tank.
I bought a 4-1/4" hole saw just for this.
Opened big hole and lots of small holes.
Welded a little bit in the inner edge of ring, then grinded it.
The fuel pump bracket length is longer than the fuel tank height.
I cut the bracket.
I'll assemble an electric fuel pump to the bracket next time.
01-15-2020, 08:32 AM
#455
1977 20' Argosy 20
Matsubushi
, Saitama
Getting rid of old paint on the tank with scrapers..
Then I painted POR-15 on it.
And an electric fuel pump is ready to go!
I installed the fuel tank to a chassis but a filler neck is not good in the proper place.
Those are close and offset.
I cannot connect it by new filler hose.
However, I don't want to use the original one.
That's terrible shape.
Here is the picture of the original "twisted" fuel filler hose.
I'm thinking about solution of this issue.
If I don't use fuel tank brackets (distance bracket?), the tank will get away a little bit from the filler neck. So it might be able to connect those.
The other option is do not use the original fuel lid and filler neck.
If so, I'll weld the filler neck to the fuel tank directly!
I think that's OK, I'll open a side compartment panel (next to the fuel tank) then filling gas in the tank.
I'm still thinking what I should do.
01-15-2020, 08:51 AM
#456
Richmond
, Kentucky
Yuki,
You've got the cleanest tank inside that I've ever seen! Nice work
You might check out Filler Neck Supply for hoses and fittings that might work.
Airstream did a horrible job with their fuel tank installs and I'm sure you can come up with a better solution. If possible you should try and use the original fuel door.
We have an old saying, Where there's a will, there's a way
01-15-2020, 09:08 AM
#457
Richmond
, Kentucky
Something I forgot to mention is you might want to consider incorporating a vent line from the tank up to the filler neck opening. Look at my thread for examples on how I did this.
Good luck!
01-16-2020, 12:30 PM
#458
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
I don’t know about a direct welded connection, due to vibration, it might crack. You might be able to use , exhaust pipe, ready made bends, and stainless steel clamps, to get it to work. You are doing a great job. We are all having fun watching your project. Thank you. Good luck.
01-18-2020, 08:02 AM
#459
1977 20' Argosy 20
Matsubushi
, Saitama
Yuki,
Brad, Thank you
Yes, the inside of tank condition was unexpected. That's not bad!
I'll search those parts later, thank you for the information.
I have already found several horrible jobs in the Argosy.
Yes, I know it would be better way to fill gas with the original fuel door.
But I need to make a hole on the floor and a filler hose cover in the cabin. If possible I want to avoid doing that..
I'm thinking about a vent line right now.
However, my filler neck doesn't have a vent line fitting..
I bought a fuel filler cap which has a relief valve (probably vacuum and pressure) so I was thinking to remove a vent valve from the fuel tank.(My electric fuel pump unit has a rollover vent valve)
I saw your thread, you have a carbon canister in the Argosy.
I'm thinking about I should use that in my setup or not. If I use that, I should keep the vent valve.
Anyway, my Datsun has a carbon canister although it hasn't been connecting anything since was replaced SU carburetors.
(At the bottom right in this picture)
I detached Datsun 5 speed trans because of to replace a flywheel last weekend.
It's very lighter and smaller than a 4L80E so I didn't need a transmission jack, a lift or whatever while at work.
It's so easy
01-18-2020, 08:22 AM
#460
1977 20' Argosy 20
Matsubushi
, Saitama
Bibbs, Thank you
I meant direct welding a filler neck on the tank like this!
That style is standard of trucks over here.
If I use that style, do not need some fabrications or modifications at the floor and interior.
But I need to open side compartment door when filling gas in the fuel tank.
