Old 04-25-2022, 05:08 PM   #1
1977 24' Argosy 24
Orlando , Florida
Wheels and tires
Hi all, I own an Argosy MH 24” from 1977, I need to replace the tires but want to get better options switching them from 16.5 to 16. I have read so many threads but haven’t found the model number of the wheels used for this switch.
I came across this wheels and asking all the experts on this field if I have the right wheels
Front wheels
https://www.4wheelparts.com/p/ion-wh...LGB-167-6681FP
Rear
https://www.4wheelparts.com/p/ion-wh...LGB-167-6681RP
Also read that for the rear inner is better to get steel any reference?
Thank a lot
Silvia
Scbohorquez is offline   Reply With Quote
Old 05-29-2023, 03:12 PM   #2
1977 20' Argosy 20
Arlington , Texas
Wheel Change for 1977 Argosy
I have changed out the 16.5” wheels on two different Argosy motorhomes to 16” wheels. The first time I used Alcoa wheels and then when I got ready to change the second Argosy, Alcoa quit making the ones for the Chevy Chassis. The only wheels available were the Ion wheels. I purchased mine from Summit Racing who has a large warehouse here in Arlington Texas. The Ion wheels worked just fine.
Very important - do not put the Aluminum wheels on the rear inside. You must use a steel wheel on the rear inside. On the Chevy chassis, the wheels are hub centric, which means the weight is carried on hub and not through the lugs. The “thinner” steel wheel allows the thicker aluminum wheel to fully engage the weight carrying diameter of the rear hub.
I used Michelin LT225/75R16 Load Range E Tires which gives the same outside diameter as the original 8.75/16.5 tires and the speedometer retains its original accuracy.
GWallace is offline   Reply With Quote
Old 05-31-2023, 03:00 AM   #3
1989 37' Airstream 370
Cleveland , Georgia
Aren't the lug nuts ,diff for steel than alum
Krg22 is offline   Reply With Quote
Old 05-31-2023, 05:12 AM   #4
1977 20' Argosy 20
Arlington , Texas
Oh yes, when I purchased the Ion Wheels from Summit Racing, I also purchased a set of appropriate lug nuts. When I changed to the 16” wheels, I bought 2 front Ions, 2 rear Ions, and 3 steel wheels. (And aLso 7 tires). Two of the steel wheels are on the rear inside and one for the spare on the third steel wheel. In case of an emergency, and a steel wheel is on the outside or on the front (with reduced speed), I can can at least keep moving. With a possible steel wheel on the outside, I kept a couple sets of the original lug nuts and the original clamp rings
Several times in the past, I have lost one of the load range E 16.5” tires and could not obtain load range E tires away from major metropolitan areas in a timely manner. Therefore all of my tires including the spare are Load Range E tires. The front axle is where the Load Range E’s are required, the rear axle can use Load Range D’s. The weight on the front axle makes the D’ and steel wheels marginal (reduced speed) according to tire and wheel specifications. That is why in my case, I have all E’s and kept some of the original lug nuts and clamp rings.
Old 06-01-2023, 05:01 AM   #5
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Although the lug nuts are different for steel/alloy, you select the type the lug is matting with. So as Gregg says, if the lug is matting with a steel wheel, use the steel wheel lug, and vice versa.
This is not an Airstream problem but relates to any vehicle fitted with alloy wheels but using a steel wheel (for example a space saver) I even have it on my Nissan NV200 which has alloy wheels but a steel spare - have to change lug nuts when using the spare.
martin300662 is offline   Reply With Quote
Old 06-07-2023, 08:15 PM   #6
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I see several Ion wheels on the summit website. Do you have the part number you purchased?
Gregsch is offline   Reply With Quote
Old 06-07-2023, 08:51 PM   #7
Boxite's Avatar
2008 22' Safari
16.5 Wheel are a throw-back to WW2 Military vehicles that used them.
GET RID of ihat system…because your are at a disadvantage when buying tires and other parts. It’s and OBSOLETE SYSTEM.
Old 06-09-2023, 05:32 AM   #8
CapriRacer
CapriRacer's Avatar
I'm in the , US
Front wheels
Rear
Thank a lot
Silvia
I am sure others would benefit if you told us what you did - with details, of course!
CapriRacer
Want to learn about tires? Please visit my website: https://www.barrystiretech.com/index.html New content!
CapriRacer is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 280 11-07-2021 10:46 PM
2...2016 aluminum wheels and with Goodyear Marathon tires and spare... Johnnyooo Airstream Classifieds 0 10-24-2017 03:14 PM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
