Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-09-2016, 11:31 PM   #1
4slice
4slice's Avatar
1977 31' Sovereign
Chase , British Columbia
New regulator and ss hoses
Hello all,
It's been a long time since I've posted anything, but I just changed out my 40 year old hoses and regulator after smelling LP gas at the tanks. The pigtails had many cracks.
In keeping with the shiny Airstream look, I opted for stainless overbraid pigtails. The only place I could find them was at Vintage Trailer Supply, and they had to special order the 36" length from their supplier (thanks Vintage!!). I also bought a new auto-changeover regulator from them.
I wanted the new setup to fit under the original plastic cover, thus I also needed to use 90 degree elbows at the inlets so the pigtails would come up from below as per the originals. I went to the local propane shop and they said there were no 90 degree inverted flare fittings, so they installed some regular elbows and added the flare fittings below. This made the assembly too wide for the plastic cover, so I offset the regulator to the right and the inboard pigtail sticks out of the cover. It's not noticeable from the usual viewing angle.
I got rid of the copper tubing snake that came down from the outlet, and replaced it with a 36 inch black rubber hose. In order to avoid chafing at the A-frame, I covered the hose with a 3/4 inch plastic loom. Looks far better than the original, and it all works great. Maybe my tanks won't need refilling as often now, lol.
Happy camping,
Gary
Chase BC
Name:	Stainless Pigtails.jpg
ID:	264142   Click image for larger version
ID:	264144   Click image for larger version
Name:	Hose to Copper Connection.jpg
4slice is offline   Reply With Quote
Old 07-24-2016, 11:24 PM   #2
1973 25' Tradewind
Redding , California
Love it.
I just replaced my regulator and hosed as well. On my '73 Tradewind. Question. My regulator was mounted to the bar that secures the propane tanks. Yours is mounted directly to the body. I like that idea. Where did you get the grey cover that hides the regulator?
oh! and do you cover your tanks? It looks like the braided lines would get in the way of a traditional cover.
Thanks!
John
Leadvox is offline   Reply With Quote
Old 07-25-2016, 07:17 PM   #3
4slice
4slice's Avatar
1977 31' Sovereign
Replacement ss pigtails and regulator
The original Fisher regulator was factory mounted to the front wall, and came with the plastic hinged cover. It had a little round window that was visible through the hole in the cover. The window would show a red bar if the tanks were empty. The original regulator was much larger than the new one.
The tanks aren't covered, so I wanted to have the ss braid to add some bling. One day, maybe when I retire, I'll tackle a polish job on the trailer and tanks. I think polished tanks look great. The new setup helped clean up the cluttered look, so I'm quite pleased with it.
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 05:59 PM
belts, hoses and rear fuel pump for 1986 345 MH? Jenniflow Classic Motorhomes 12 05-26-2012 12:42 PM
345 mo safety valve flexible hoses and fittings moonshine LP Gas, Piping, Tanks & Regulators 12 02-13-2010 03:27 PM
Water hoses ALANSD Mechanics Corner - Engines, Transmission & More... 8 01-26-2003 10:46 AM
What Water Hoses to Bring? rmmm68 Fresh Water Systems 7 01-14-2003 07:39 PM
