Go Back   Airstream Forums > Airstream Community Forums > Our Community > WBCCI Forum
Old 11-09-2003, 02:10 PM   #1
Profile:
BIG RED #'s
I am preparing to polish my unit but can't get the previous owner #'s off.
Any Suggestions?
Chris Deeley is offline   Reply With Quote
Old 11-09-2003, 04:44 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , Texas
Images: 143
Wet Sand
You might try to wet sand the area around the numbers.
I have done a few areas on the 345. Started with 1000 grit on the bad areas, worked up through 1200, 1500, 1800, and 2000.
Use lots of water while sanding (a spray head barely misting works well).
The sand paper is available at most automotive supply houses.
Finish with a power polish of some sort.
Dennis
WBCCI # 1113
AirForums #1737
Old 11-09-2003, 04:48 PM   #3
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Before you resort to mechanical means..........
Try an Iron and a wet towel. Place the wet towel over the number and use the iron to create heat and steam. This will soften the glue and make the plastic from the letters pliable to an extent. This should allow for a good removal, then you can use a solvent to remove the glue residue.
The thought of sanding the skin scares me
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 11-09-2003, 05:10 PM   #4
87MH's Avatar
Katy , Texas
Images: 143
"Shadows"
Correct on the mechanical removal. Actual removal of the plastic and glue was accomplished by "Aircraft Stripper" - nasty stuff. Contains methyl chloride. Don't get any on your hand, can't tell it's there for a while, and then you can't stop the burn.
Don't ask how I know.
The sanding was done lightly for removal of the "shadow" left after actual removal of the plastic (vinyl?) numbers. Actually, on mine, TWO sets of shadows were present.
I tried polishing the shadows off prior to sanding, but was not successful. A heavy sanding was not necessary, and the entire area polished out quite nicely with not much effort.
Dennis
WBCCI # 1113
AirForums #1737
Pingbacks are On
Big Red Numbers Sasquatch WBCCI Forum 88 02-10-2006 03:04 PM
Posting Drawing from MS Paint...too big jaco Forum How-To's & Support 2 02-08-2004 09:30 PM
BIG BIG AIR HUG!!! & "eh" Streamin' THANKS GT1963 Our Community 6 01-30-2004 07:50 AM
Lunar eclipse to turn moon red jpurdy Off Topic Forum 4 11-09-2003 08:59 PM
Re. red #s on front of AS ? jwaldin Our Community 4 12-29-2002 06:18 PM
SEO by vBSEO 3.1.0
