Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 05-28-2015, 08:43 AM   #41
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
I'm all for people learning their RV's systems but the electric systems on these rigs have a learning curve. I'm just advocating it be easier.
Perhaps the fact that these types of RVs are marketed to people who have so-called sheltered lives is the problem. I'm not looking to become an electrical engineer; I just want to take fun excursions.
Anyway, the ebook and spreadsheet are both helpful... Thanks
2014.5 Airstream Interstate Ext.
AI Facebook Group
k9jackie is offline   Reply With Quote
Old 05-28-2015, 08:52 AM   #42
Mantua , Ohio
The owners manual is also very helpful. Jim
Old 05-28-2015, 05:12 PM   #43
k9jackie's Avatar
Let's agree to disagree
Airstream Interstate Facebook group
https://m.facebook.com/groups/1399633380341777
AI Facebook Group
Old 05-28-2015, 05:57 PM   #44
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Marks71 View Post
I uploaded excel and pdf versions. Not sure if this will work.
Attachment 239443
Attachment 239444
On mine, the inverter powers both the front outlet by the 2nd row streetside seat and the one in the rear behind the curbside dual wheel house. Also the fridge only runs off the house batteries if no 120 VAC is available, i.e., no inverter, no shore power, or no generator.
I like the matrix idea but it almost has to be 3D which sort of defeats the purpose.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 06-05-2015, 03:43 PM   #45
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Ashland , Oregon
Send a message via AIM to albert Send a message via Yahoo to albert
Perhaps this is the thread to ask this question... I sure hope so! I have a new Xantrex 2000w inverter that I want to somehow "hardwire" or tap into an outlet, so that i dont have to crawl under the bed to plug a phone in to charge, and I would like to use it for a blender, coffee maker, etc. Can someone advise how to run wire from the "outlet" on the inverter to an existing outlet and wire it into that outlet? There is a outlet above the inverter where I positioned it under the back bed now, so it would be clean to do this, i just dont know what wire to use or what to do to get it "hardwired"
Thanks in advance!
albert is offline   Reply With Quote
Old 06-05-2015, 05:37 PM   #46
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Thanks in advance!
Go to the Xantrex web site and down load a copy of the installation instructions for the specific model Xantrex 2000w inverter you have. They can be found under the "Support" tab. Here is a link to the Xantrex inverter product page.
http://www.xantrex.com/power-product.../overview.aspx
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 06-05-2015, 06:25 PM   #47
albert's Avatar
1970 29' Ambassador
1957 26' Overlander
Ashland , Oregon
Thanks Mike, but I know how to install the box, its very simple, but I want to take the GFI outlet that it comes with and wire it up to an outlet on the wall. Does that make sense?
Old 06-05-2015, 07:12 PM   #48
73shark's Avatar
If it's a standard GFIC outlet, it will have a set of terminals labeled LOAD. You can connect one or more outlets to those and they will be protected but will also be off when the GFIC is tripped.
Old 06-06-2015, 09:37 AM   #49
2024 Interstate 19
Fulton , Maryland
See if any of these help.
http://diy.stackexchange.com/questio...a-gfci-circuit
See attached diagram for details.
Name:	ImageUploadedByAirstream Forums1433605012.757380.jpg
- - Mike
- - Mike
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
Gaucho? Silly newbie question egad Airstream History 4 05-18-2012 07:25 PM
May day! May day! I have a leaking Argosy bpappas Argosy Motorhomes 6 08-08-2011 09:00 PM
TAC Illinois Rally - Starved Rock SP - May 13 to May 15 Air Apparent Other Rallies & Events 4 05-14-2011 08:58 AM
silly ball height question. AV8 Hitches, Couplers & Balls 7 11-09-2003 05:32 PM
