Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 07-30-2015, 06:43 PM   #1
2015 Interstate Ext. Coach
Manassas , Virginia
Fresh water pump turns on by itself
I have a 2015 Interstate Grand Tour (about 3 weeks old). On three occasions, I have parked the RV in a barn and come back a few days later to find the water pump running. The fresh water tank is about half full and the RV is on level ground. I shut the pump off and run the kitchen faucet until the line is empty. There is not much pressure behind the water coming out of the kitchen faucet. I then turn the pump on and let it run until the lime pressurizes and the pump turns off and there is strong pressure behind the water coming from the faucet. Also there is air in the line initially until the water flow clears the line.
What would cause the pump to start running for days and not pressurize the line?
How much wear and tear can the pump withstand running (dry?) before failing to produce pressure?
Thanks.
curmugeon is offline   Reply With Quote
Old 07-30-2015, 06:48 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Maybe there's more air in the lines somewhere and the pump is unable to compress it enuf to reach the shutoff pressure.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 07-30-2015, 06:52 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It's a diaphragm pump, and can run dry for a long time without being damaged, unlike an impeller pump. The most likely damage— if any— would be due to it overheating; most pumps are cooled by the water they pump. So if it still runs, you're good.
The pump is supposed to be self-priming, and from what you wrote, it appears to be priming properly because you do get some flow when you open a faucet.
So my guess is that the check valve that keeps water from flowing backwards into the tank is not working properly. So what happens is, the pump activates from the loss of pressure and self-primes— or tries to. but with no faucets open, it compresses a bubble of air as soon as the pump primes. Most likely place for that bubble is the water heater. Try manually opening the pressure relief valve on the water heater to "burp" the heater, and see if that helps. But make sure the water heater is turned off and allowed to cool first— no need to scald yourself.
Old 07-30-2015, 06:54 PM   #4
"Cloudsplitter"
Thumbs up
Find the leak and shut the pump off when you don't need running water, sleeping or away from the trailer.
Learned that lesson when I woke up in the middle of the night with the pump running and the bathroom floor soaked.
Name:	Water leak 002.jpg
Old 07-30-2015, 07:38 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The internal check valve might be bad right out of the box....
Old 07-31-2015, 07:06 AM   #6
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Where do you actually turn the pump on and off? In our classic there is an obvious switch for this; in our Interstate there is no obvious switch so we assumed it was a force-induced on/off whenever you open a faucet.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 07-31-2015, 08:23 AM   #7
Over the galley sink there should be a row of three (or maybe four) switches. One of these controls the pump, the rest control various lights.
When the switch is on, the pump's own pressure switch controls the pump. When the switch is off, the pump is off.
Fresh water tank filling by itself Jwestman Fresh Water Systems 4 08-21-2013 09:14 AM
Key Turns and Turns..is this normal? help moormansmari Doors & Locks 10 11-25-2008 04:57 AM
Olympian wave 6 turns itself off pauly g Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-07-2008 08:02 AM
Door locking by itself! FiveGreers 2005 - 2010 Safari 6 08-03-2006 09:06 PM
