01-24-2017, 12:42 PM
2016 28' International
Redmond
2017 Super Duty TPMS
Has anyone installed the 2017 Super Duty TPMS kit on their Airstream?
I found this note "Four (4) TPMS Sensors o (note: wheel sensors only fit wheels with J-type flange wider than 3.5 in (88.9 mm) and a .452 in (11.48 mm) valve stem hole stem hole.".
I'm assuming they would fit but maybe someone knows for sure?
01-26-2017, 07:00 PM
2014 25' FB Eddie Bauer
Glen Arbor
, Michigan
Thanks for posting. I have the same system and question.
01-29-2017, 03:22 PM
Redmond
I ordered Ford part HC3Z-1A189-C, should have the answer in a week or two.
02-12-2017, 02:22 PM
1967 22' Safari
West Fork
, Arkansas
I have a similar question for the 2017 Ford F-150. I've ordered a Lariat with the max tow package. Of course the truck has TPMS but could my two wheels on the Safari be added? At present I have Tire Minder that includes a booster to get to the monitor but it would be terrific if trailer were combined with one system and one display.
02-15-2017, 07:39 PM
Redmond
Here are the wheel requirements for using the Ford Trailer TPMS.
1) A wheel with a J type flange, this is apparently most passenger and trailer wheels and is denoted with a J in the size usually on the back of the wheel. For example 16x6.0J.
2) The wheel width must be greater than 3.5", so a 16x6.0J wheel has a 6.0" width and will work.
3) 0.452" diameter valve stem hole, this again is most passenger and trailer wheels.
I upgrade to Michelin tires on Sendel T03 rims which meet all of the above requirements.
I'll post a write up on my blog in a week or two with more details.
02-21-2017, 01:15 PM
1967 22' Safari
West Fork
, Arkansas
Matt,
You really know this stuff! Thanks so much for your thorough blog.
02-21-2017, 07:29 PM
Glen Arbor
, Michigan
This is super helpful...thank you very much.
Do you know if the 16's which come with the Eddie Bauer are compatible with the TPMS.
02-21-2017, 08:33 PM
Washington
Matt will you be installing the camera too? I have always worried about this considering its wired and there is no good way I know of to route the camera wire up top of an airstream...
02-21-2017, 09:37 PM
Redmond
The TPMS will work with any of the Sendel wheels including those on the Eddie Bauer edition.
02-21-2017, 09:44 PM
Redmond
I'm not planning on it.
Ideally you'd mount the camera above the rear window, I have a rear bedroom that has closets on both sides of the bed. If you have the same you could run the wires up the back of those then drill a hole through the roof.
You could also mount it near the license plate frame, that should be pretty easy.
02-22-2017, 12:03 AM
2017 30' Classic
Bay Area
, West Coast
Originally Posted by Mgieselman
Nice blog, I have not installed mine yet, will do when I need new tires. Trailer is only 5 months old. I just purchased a TST system for now, and use the wireless camera that came with the 17 Classic
02-22-2017, 07:40 PM
Glen Arbor
, Michigan
Great...thanks very much. Super helpful.
02-22-2017, 11:20 PM
2007 22' International CCD
Corona
Good data. Thanks!
03-22-2018, 06:16 AM
2018 26' Flying Cloud
Corpus Christi
Matt, thanks for the nice write up! How did you secure the sensor receiver to the A frame, with zip ties or self tapping screws?
03-22-2018, 07:37 AM
2007 28' International CCD
Springfield
I secured mine with large zip ties and placed the signal pickup box to the center of the forward axle.Works great.
03-22-2018, 11:22 AM
Corpus Christi
Thanks for the reply, Moflash. Noticed your hometown of Springfield. I’ve been there many times. I’m originally from Mountain Home, AR.
03-22-2018, 07:18 PM
Springfield
Haven’t been to Mountain Home since the 70’s but I remember it being a nice little town.
03-26-2018, 01:42 PM
Opinionated newb...
2018 25' Flying Cloud
League City
, TX
Well what do you know.. my Mom and her Husband , are there in Mountain Home, pretty region to be sure
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
