Go Back   Airstream Forums > Airstream Community Forums > Our Community > Community Polls
Old 11-01-2011, 01:52 PM   #101
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Rsvp
Originally Posted by Chris
...then the A-frame is NOT bent (or cracked)...I invite members to review my logic, and perhaps perform the test for themselves and report back results...
The A-frame can be cracked without being bent.
Modulus of elasticity is one thing. Cracks are another.
Thanks for the invite. I will express regrets now.
Tom
Old 11-01-2011, 03:49 PM   #102
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton , California
Send a message via AIM to tyggeln Send a message via MSN to tyggeln Send a message via Yahoo to tyggeln
True point, I guess I extended the assertion a bit far. I'll leave it as NOT bent.
Chris
tyggeln is offline   Reply With Quote
Old 10-08-2012, 07:44 AM   #103
L911's Avatar
1971 18' Caravel
Cookeville , Tennessee
Images: 12
We use the weight distribution hitch (ball mount) without the bars and a single sway bar. 2001 Suburban towing a 73 Ambassador 29 (25' in reality). Electric brakes on trailer.
L911 is offline   Reply With Quote
Old 10-08-2012, 07:58 AM   #104
Not a good setup.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-09-2012, 06:07 AM   #105
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 10-10-2012, 10:31 AM   #106
L911's Avatar
1971 18' Caravel
Images: 12
Actually it works great, Its no different than just using a standard 2" slide ball mount, except that it gives you the option of using an anti-sway bar.
Old 07-16-2013, 04:19 PM   #107
LFC
Memphis , Tennessee
25 ft. Safari, 800 lbs bars...I've got a single sway bar but have never noticed a need for it.
LFC is offline   Reply With Quote
Old 10-07-2013, 07:26 PM   #108
1960 28' Ambassador
Libertyville , Illinois
After 16,000 miles of trouble free towing with a 6,000 lb Equalizer, I replaced my 25ft trailer with a 30 footer. Specs are similar - old at 4,300 lbs / 470 lbs hitch weight vs new at 4,700 lbs / 400 lbs hitch weight. Yet I experience a lot of bouncing at 55 mph; it goes away at 65 mph. Any thoughts would be appreciated.
Short563 is offline   Reply With Quote
Old 10-07-2013, 09:15 PM   #109
How old is the 30 footer?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-08-2013, 11:44 AM   #110
1960 28' Ambassador
It is a 2012 - I have to come clean here - it is not the right time for me to own an Airstream - it is an SOB.
Old 10-08-2013, 12:02 PM   #111
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Originally Posted by dbradhstream View Post
Randy - I suspect I know what happened to you and I suspect its the same thing that happened to me. I bought my AS and Equalizer at Bates AS near Tampa, I suspect you did too. The shop manager told me NOT to grease the Equalizer so we took 3 or 4 trips with the AS creaking and groaning like a worn out old battleship. It was so loud folks would look weird at us as we pulled into the campgrounds.
Please see the Equalizer website or owner's manual. It expressly says that you SHOULD grease the hitch and that you MAY grease the bars themselves. Do that and you'll be towing in peace and quiet. I use a marine grade hitch lube that works great.
We just traded up from our 08 20ft Safari to a 25 International and the dealer gave me a tube of equal-I-zer grease that is recommended by Equal-I-zer to use on the ball and the bars. When I asked what the difference was to regular grease he laughed and said that mainly is washes out of clothing much easier. I don't hear any noises now. I am using 1000 lb bars with an HD 1/2 GMC.
No sway at all and toes much better than the single axel.
George
gandttimes is offline   Reply With Quote
Old 10-08-2013, 12:59 PM   #112
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I have a 27FB. I'm using the 1,200 bars. It does a fabulous job redistributing weight. Yet to have porpoising problems. I've not greased the bars and you can hear me coming. Its a trade off, messy to me or noisy for others.
kscherzi is offline   Reply With Quote
Old 10-08-2013, 05:17 PM   #113
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
1,000# bars-
Creaking and groaning-
I don't bother to grease it because of getting grease on my hands and clothes.
I might try the bracket jackets to quiet it down some.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-08-2013, 05:32 PM   #114
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Originally Posted by m.hony View Post
1,000# bars-
As I said in a previous post . Equal-I-zer makes a special grease that comes in a handy tube with a small tip that makes it easy to apply to the needed areas . It works a lot better than the other lubes I have tried, and cleans up easily.Should be available anywhere that sells the hitch.
George
Old 10-08-2013, 06:01 PM   #115
TomW's Avatar
1967 26' Overlander
A little bit of startup noise is usually okay
...Creaking and groaning-
I don't bother to grease it ...
This thread is so big that I neither remember what I posted in it to be included in the "new post Tom!" list nor am I inclined to look it up.
But, depending on the hitch, a certain amount of noise is okay from any friction-based hitch until one is down the road a bit. That is certainly the case with my Reese Dual-Cam.
Greasing everything for noise abatement is not always the best initial course of action.
Tom
Old 10-09-2013, 05:30 AM   #116
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That's what disposable gloves are for, to keep grease off your hands. You can buy boxes of 50 or 100 surgical gloves in the pharmacy department at Walmart. As you remove a glove, turn it inside out by gripping the cuff and pulling it off, rather than gripping the fingers to pull it off. With practice, you can remove both at once, with both gloves inside-out, one inside the other. Neat and clean.
As for keeping grease off your clothes, an inexpensive barbecue apron will work wonders.
Old 10-09-2013, 08:03 AM   #117
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
1000# bars modded to ~800# bars for a bit more flex...making it easier on our Int.LE 25 EB A-frame...suggest that you try the EQ pads/jackets on your L-brackets ... much quieter and no grease needed.
I can only ask ...at an elevated retirement age and with 15+ of my early years "greasing" in the automotive industry ... what is special about EQ brand grease...other than it responds differently to water / detergent ...LMAO. Likely not the best "lube" in an area with frequent rain / moisture - you want grease to stay in place and not be displaced or removed with water!
By design, the EQ brand hitch uses friction to control sway; so, some friction is necessary to get the job done. Frequent cleaning (with some sort of penetrating oil) and re-greasing of the ball and lubing the pivot points of the arms is also our regular regimen before departure and is suggested. Ask your maintenance folks (auto or RV) to pump some grease into a plastic (we use a yellow med type) jar for you... apply to your ball / coupler with a screwdriver ... wipe off screwdriver with a rag or towel ...grease never touches your hands. One small jar will last for many years as you don't need globs on the ball, just an even coating.
We also use a larger vitamin pill jar with the neck cut off to cover the ball when unhitched ... they are cheap and disposable but -amazingly, the surface tension of the grease on the ball will keep the "pill jar" on the ball when driving down the road unhitched. I have two spares, but rarely have to replace the pill bottle ball cover. Toss the ball cover into a plastic sack between uses and throw away the sack when it gets too soiled for your preferences.
Old 10-09-2013, 12:59 PM   #118
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
My experience with the EQ grease was limited to my last and initial trip with our 25fB and during the 15 days on the Oregon and Washington coasts we had 4 days of moisture and 11 of rain. I found that the EQ grease mostly stayed where it was put with just 2 touch ups and unlike the regular HD grease I had been using didn't seem to pick up every bit of airborne dirt and sand. I still use the nitrite gloves, but don't notice near the mess on them, and can often use them over again till they tear.
Not trying to sell it, just mentioning it as an alternative that I found after 22 years of trailering, that I would recommend as an alternative to squeaking and groaning of the bars.
Also after 50 mi on the I 5 in pouring rain with transport trucks all around and not the best road surface I can attest to no loss of dampened sway control and no porpoising.
just my 2c
Old 10-17-2013, 04:26 PM   #119
1960 28' Ambassador
As a follow up to #108 - I spoke with Steve at Equal-i-er and he told me that transferring a bit more weight to the tow vehicle would help. Originally I had zero change in height (as measured by the wheel wells) - now I am about 1" which is within their guideline. Tows great now with no bouncing at any speed!
Old 10-17-2013, 05:54 PM   #120
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
Wellfleet , Massachusetts
Look at the Hensley hitch
Don.44 is offline   Reply With Quote
Hensley Arrow Hitch Les Hitches, Couplers & Balls 116 12-14-2015 07:41 AM
Hitch size Jim Sease Hitches, Couplers & Balls 16 10-12-2010 10:04 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
