Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 10-08-2009, 08:15 PM   #1
lascassas_camper
Apache_Camp's Avatar
1975 Argosy 24
Gatlinburg , Tennessee
Cargo box
Well I moved my LP tanks (I use the little bottles) and mounted this cargo box on my tongue. So far it hasn't rubbed going around the block on a test drive. Its a rubbermaid type cargo box from TSC, originally for a ford ranger/s10 pick up. Its bolted to my trailer tongue. The jack handle will turn, but its close!
*1975 Argosy-Airstream 24
*1995 Palamino Mustang Popup Camper
*1996 Buick RM Wagon 5.7L V8, AT/OD, tow pkge, coil over shocks, hitch, brake box, cooler.
*Good Sam Club Life Member
Apache_Camp is offline   Reply With Quote
Old 10-08-2009, 10:01 PM   #2
Retired.
. , At Large
You can get a tongue jack that rotates vertically, so you don't scrape your knuckles when cranking it.
A bigger concern is where the latch-up arms are for your WD system. The chains should be pretty much vertical when hooked up, and it looks like they are extended way far back on the A-frame. If that's how it is, and it's not an optical illusion, you'll probably break the chains the first time you go around a tight corner, at best.
Old 10-09-2009, 07:25 AM   #3
lascassas_camper
1975 Argosy 24
That just where the chains are hanging for photo op, they will go vertical if I use them. I will be adding a new stablizer bar though,
Old 10-09-2009, 08:07 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
In general this is not a good arrangement. As mentioned you will not be able to use the chain hangers unless you mount the box much higher. While your test run showed that you did not hit the box that is not the time when you need to be concerned. You can not turn sharp enough while driving forward to hit the box. However while backing up you can very easily jack knife and it it.
2004 Excursion 4x4
Old 10-09-2009, 10:39 AM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
What did ya do with the LP Tanks??? and it depends on what or how much weight U intend on puttin in the box.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 10-09-2009, 12:33 PM   #6
lascassas_camper
1975 Argosy 24
We use electric, no gas in our trailer at all. I carry portable tanks in the cargo box for the portable gas grill. We have all new electric camper appliances.
I tried backing up and turning, didn't hit, my hitch sticks out from under the tow vehicle further than most. I bought the hitch extender on ebay and had it welded at a competant welding shop (instead of bolting it on).
Regardless, the box is staying.
Old 10-09-2009, 12:53 PM   #7
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
Apache Camp,
The box is a cool idea as its handy to have the extra storage. I think the issues the guys are bringing up is the variable weight that box can add to your overall tongue weight. Depending on what your puting in that big box (and you can store lots of stuff it you wanted) it could increase the tongue weight by a few hundred pounds. Sounds like your going to store pretty light weight items though.. and...
The brackets should really be directly in line with the ends of those bars so when turning the bars dont tug the brackets off the frame rails and damage your box. I guess you could do some more modifications to the mounting to overcome that. Like you say.. the box is staying so it would be best to make it as usable and safe under all conditions.
Vin
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 10-09-2009, 03:16 PM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Yep, what he said.
Now, at the risk of being too frank... Airstreams are classic coaches, and some think all owners are millionaires or snobs. That just isn't true. However I will put myself at risk of being classed with the snobs and say bluntly - I've seen nicely done boxes custom made from diamond plate - and I've seen modifications to trailers that tend to make one think "redneck meth lab trailer". Yours? It's an ill conceived, ill fitted design. Put that box back on a truck where it belongs. It looks like hell; It's deprived you of propane tanks to run a furnace, water heater and refrigerator, it will affect the aerodynamics of a trailer that's built to be aerodynamic; and you WILL jacknife your tow vehicle into it while backing up.
Give yourself credit and admit you can do better. Most of us have at least one or two prototypes for every project we complete.
Curses, FOILED AGAIN
Old 10-09-2009, 03:28 PM   #9
_
the box is STAYING folks....
4 things 'camp....
1. u r towing with buick roadmaster?
that thing already has more space that some apartments or condos, fill the sucker UP!
2. rotate (roll) the box 90 degrees toward the trayla...
this will give u clearance for the chains/brackets, make the box more aero di namic and mysterious looking...
3. be sure to add a box at the rear bumper too!
a 2nd box will balance the extra tongue load,
and since lp tanks are in the front box (?? remove tank brackets but carry tanks in a box, hmmm??)
how 'bout some gasoline cans and a big ol' generator on the bumper???
4. you've got PLENTY of flat space on TOP of that box for more creative additions!
a couple of chairs mounted up there would make for a great spot to ride!
cheers
2air'
Old 10-09-2009, 07:22 PM   #10
lascassas_camper
1975 Argosy 24
I think your over-estimating the weight of that platsic box....
Colorado to Washington for cargo? Zeppelinium Off Topic Forum 2 03-13-2008 01:58 PM
Cargo Weatherstrip? ajheinonen Airstream Motorhome Forums 3 06-06-2007 10:29 AM
Cargo Box adchisholm 2005 - 2010 Safari 2 04-30-2005 08:41 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
