Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1987 - 1989 Excella
Old 06-23-2015, 12:25 PM   #1
1989 25' Excella
Albemarle , North Carolina
Angry Converting every thing to electric (110 volts)
I am 84 years old have been camping since the late 50s. Have owned 5 TT, last 3 were airstreams. one in Europe. I would like to convert every thing in my 89 25 ft excella to 110 volts. My main objective is to remove the two 12 volt batterys. I could most likely do it with one exception. How to power my break a way switch for the electric brakes. Any suggestions. We now only camp in full hook up camp grounds. Thanks for any suggestions and/or solutions.
eldin is offline   Reply With Quote
Old 06-23-2015, 12:30 PM   #2
2019 23' International
Portland , Oregon
maybe you can get an engineer to design a storage circuit for you. You'd need to know the maximum current and time required to bring your trailer to a full stop after it detaches at your maximum speed and load. Then a gigantic capacitor with a load resistor sized to deliver the amount of current etc etc... kind of a big deal I think... Maybe a small motorcycle battery charged by the TV would be easier
leedav is offline   Reply With Quote
Old 06-23-2015, 12:33 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
If by "convert everything" you mean "convert the 12v electrical system to a 120v system" you really don't need to do that if all you want to do is eliminate the big wet-cell batteries. A modern converter-charger will provide you with stable DC power without having a battery in the loop if you wish, and you could buy one of the small AGM batteries designed to support breakaway switches for trailer that don't need a battery otherwise.
If you mean to convert your various propane appliances to 120v that's another issue, and you'd be better off adding 50A service to your trailer if that's your goal, since the demands for that could be pretty high for a 30A setup.
— David
DKB_SATX is offline   Reply With Quote
Old 06-24-2015, 05:49 AM   #4
Mantua , Ohio
You can buy breakaway switches with their own battery pack.
xrvr is offline   Reply With Quote
Old 06-24-2015, 12:32 PM   #5
2000 36' Land Yacht XC Diesel
Fresno , California
I know on my Moho I have the option to switch between propane and 12v or 110 on my refrigerator and water heater. And my stovetop is propane only. I've already had an instahot water heater installed. My next project is ditching propane all together. I always use my two burner induction cooktop and I'm having my oven replaced with a dishwasher. As I have a Moho I still need 12v for traveling...but I hate having to remember to refill propane. The only thing I was using it for was my outdoor grill...I may keep it for that and get an infrared grill but the taste isn't the same. My parent's class A is all electric, as are most high end class As today apparently. Gone are the days of propane it would seem.
LucasS is offline   Reply With Quote
Old 06-24-2015, 02:04 PM   #6
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I want to go to "all electric" 120 system, too. If you figure this out... I'd be very interested in knowing what to buy (converter, etc)
paddle whisp is offline   Reply With Quote
Old 06-24-2015, 02:08 PM   #7
1998 35' Cutter Diesel Bus w/slide
Young Harris , Georgia
A purely mechanical break a way brakes are possible. There are electric trailer brakes with mechanical parking brakes for sale on eBay, and ReadyBrake sells a emergency break a way kit for toads that might could be set up to activate them. ReadyStop™ Towed Vehicle Emergency Break Away Kit - NSA RV Products
But the small battery systems used with non RV trailers would be simpler and cheaper, as suggested.
Koheleth is offline   Reply With Quote
Old 06-24-2015, 04:11 PM   #8
1989 25' Excella
Thanks for all the information. For Avionstream. Looked up your suggestion on Google and believe that will do the trick. Many thanks. Ordering one now. Eldin
Old 06-24-2015, 04:16 PM   #9
1989 25' Excella
Break a way switch
Thanks for all the replies. Took avionstreams suggestion and ordered a stand alone unit. Many thanks to all.
Converting to electric heat? Foureagles Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-20-2014 01:28 PM
All Electric, Mostly 110 volt? bilby05 Electrical - Systems, Generators, Batteries & Solar 9 07-07-2012 01:50 PM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
Campground Electric/AirC/low volts??? crazylev On The Road... 20 07-26-2005 09:46 AM
Battery health with 110 volts going full time Mark Wiltrakis Batteries, Univolts, Converters & Inverters 11 03-15-2004 09:14 PM
