Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 1000 > 1993 Excella 1000
Old 11-06-2011, 11:15 AM   #1
Fort Lauderdale , Florida
Excella questions
Hi! I am new to RVing and Airstream other than knowing of their reputation.
I looked a t a 1992 Excella 1000, 32 yesterday in FL. It is shiny with upgrades and a queen/double bed in the rear.
I found a name in the appropriate section here for an inspection and am waiting for a response although I feel a bit uncomfortable having someone do this without compensation. Maybe a charitable donation?
Anyway, I would like some information on the differences between the Excella, 500 series, 1,000 series, wide body, etc.
I would probably be changing out the decor, wallpaer, counter and adding some kind of wood floor. I assume a regular contractor could handle this?
My intention is to full time and this seems like a fun way to do it.
Any comments would be much appreciated.
Thanks.
Chris
CSURP is offline   Reply With Quote
Old 11-06-2011, 11:23 AM   #2
Thanks.
Chris
I would not suggest a "regular" contractor, since they know nothing about an Airstream.
Use someone that specializes in Airstream remodeling or the like.
What you can and cannot do with an Airstream is very different from a house.
Payloads, weight and balance, axles, plumbing, heating, AC, low voltage systems, gaskets, water leaks, brakes, are all different.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-06-2011, 12:18 PM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Inspections and checklist
We have done some inspections for several trailers. We do it because we like to do it. If you find someone willing to go do it, take advantage. Offer to pay their gas and mileage, and perhaps tolls etc. for sure. There is an inspection checklist available in the forums here too.
As for remodeling, what Andy says is correct. An Airstream needs to remain flexible as it rocks and rolls down the road. A regular contractor might build it like a house and nail things so tight that it won't let it flex, and then the rigidity tears things apart.
Do lots of research on the forums before you buy. There are lots of great threads on here that will get you up and running and finding out what issues are deal breakers.
Good luck in your search!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 11-09-2011, 08:38 AM   #4
Thank you for the comments. Much appreciated.
Questions about 1987 Excella 32 foot blkmagikca 1987 - 1989 Excella 9 10-15-2013 08:15 PM
1985 31' Excella Belly Pan Questions Eugiepayset Belly Pans & Banana Wraps 3 06-27-2011 12:04 PM
About to pull the trigger on '86 Excella 32 (PICS)) DustDom Buyer Guidelines 5 06-23-2011 03:45 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
