Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 1999 - 2004 Bambi
Old 09-02-2003, 04:57 PM   #1
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Holding tank plumbing question
I recently had Airstream upgrade my black tank from an eight gallon tank to an 18 gallon tank in my 2002 19' Bambi. The holding tank plumbing is now situated much lower than the original factory plumbing -- the plumbing is now only 6" from the ground (see photo below)! That seems a bit low so I would like to poll 2002 19' Bambi owners who own a unit with the 18-gallon black tank as standard equipment. How far off the ground is your plumbing? Can you post a picture of your plumbing?
yukionna is offline   Reply With Quote
Old 09-02-2003, 05:02 PM   #2
yukionna
yukionna's Avatar
Images: 18
Oops! I forgot the photo!
I couldn't figure out how to add a photo after I posted the thread so must resort to responding to my own post!
Name:	black tank plumbing.jpg
Old 09-02-2003, 05:09 PM   #3
Rickk48
Rickk48's Avatar
Profile:
I will be interested in the replies, as I have been thinking of doing the same mod to my '01 Bambi.
Rick Klein
'01 Bambi
'99 Land Rover Disco
Rickk48 is offline   Reply With Quote
Old 09-02-2003, 05:30 PM   #4
rcaldwel
Profile:  1994 30' Excella
New Smyrna Beach , Florida
yukionna,
If I may ask, about how much does it run to have this upgrade. We have a 2001 Bambi and I was also thinking it would be nice to have a larger black tank.
Bob Caldwell
rcaldwel is offline   Reply With Quote
Old 09-02-2003, 05:33 PM   #5
yukionna
yukionna's Avatar
Images: 18
It cost about $1,000 for everything -- labor and materials -- and is a 3-4 day job.
Old 09-02-2003, 06:20 PM   #6
yukionna
yukionna's Avatar
Images: 18
One other thing I want to mention about my black tank upgrade -- the new toilet orientation!
I read somewhere (probably on this forum) that you can gain more leg room in the bathroom of the 19' Bambi's by re-orienting the commode. This is done by loosening the bolts and turning the commode slightly toward the shower. Well, when Airstream installed my new black tank, they re-oriented my commode. What a difference it makes -- no more complaints about knees banging against the closed bathroom door!
Old 09-02-2003, 09:04 PM   #7
WayWard Wind
WayWard Wind's Avatar
Profile:  2004 25' Safari
Yukinnoa, we have an 02 Bambi & as luck would have it ours was made SHORTLY after a line change, where A/S went with the bigger tank in the 19'. I'll take a pic of ours tomorrow & try to post it, so you can see the plumbing difference. I had contacted A/S, after purchasing ours, regarding the turning of the toliet & that's what I was also told to do. If you look at some of thier floor prints it appears they are now turning them slightly towards the shower. I'm also interested in a previous problem you mentioned regarding the side panel peeling. After reading your thread, I looked up an article I had clipped from the Blue Beret & David Schumman ( works for A/S ) wrote in there (see issuse June 2002 page # 50 ) that from 1999 on A/S has started using painted panels that come from Alcoa, instead of Clearcoat, to avoid the peeling problem. So what's peeling?
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 09-03-2003, 04:50 AM   #8
yukionna
yukionna's Avatar
Images: 18
On the street side of the A/S, there are three spots where the coating is coming off in strips. The damage occurred about seven feet up the side so I didn't notice the problem until the pieces of clear coat had broken free and were hanging down. Airstream attempted to strip the finish to recoat that side while my unit was at the factory, but the exposed area of the panel had changed color. Aistream tried to buff that side out, to blend the colors, to no avail so they are planning on replacing the panel this winter.
Old 09-05-2003, 07:42 AM   #9
dtbw
dtbw's Avatar
Profile:  1999 34' Limited
2002 19' Bambi
Allen , Texas
Nancy,
here is a pic of our factory setup. Ours was the first Bambi with the 18 gallon. Looks pretty much the same as yours except ours has a bracket to support the outlet (it also prevents me from rotating the drain downward, so I had to buy a ell so that my Sewer Solution would clear the gate valve handles). Sorry that I don't have a better pic, but our rig is in storage. I will be getting it midweek for a unit rally, so I will take a better pic and do some measurements.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 09-05-2003, 09:23 AM   #10
B25guy
B25guy's Avatar
Profile:  2003 25' Safari
Flower Mound , Texas
Images: 20
I have a 25C but it looks the same as DTBW's. I strongly recommend the bracket that holds the whole assembly to the underside of the trailer. I wasn't impressed by the way the factory just screwed it into the aluminum panel so I added a piece of 1" aluminum angle behind it to the outrigger about 6" forward of the existing mounting point. That's a lot of weight to be supported by friction of the joints and thim aluminum sheet metal.
B25guy is offline   Reply With Quote
Old 09-05-2003, 10:20 PM   #11
yukionna
yukionna's Avatar
Images: 18
B25guy, I'm not sure I understand what your bracket does. Do you have a photo you could post?
Old 09-06-2003, 08:50 AM   #12
dtbw
dtbw's Avatar
2002 19' Bambi
Allen , Texas
See my photo
Nancy,
Look at the photo I attached to my earlier posting. See the area above the outlet? Note that there is a metal bracket that surrounds the outlet area (between the two gate valves)providing added support and generally providing a more pleasing appearance.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
Old 09-07-2003, 11:27 PM   #13
rfield54
rfield54's Avatar
Profile:  1980 28' International
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 103
Wink
Yukionna,
The plumbing clearance on my '02 Safari/Bambi is 9" at the exit bracket and about 9 3/4" at the dropped floor that accomodates the (standard equipment) 18 gal tank. It sounds like you lose 3" of clearance with the upgrade when compared to a newer Bambi . . . it's still worth it though. It could be more disadvantageous. I'm told the '92 thru '97 (21') Sovereign's have only 5" of clearance at the same location . . . Roy
rfield54 is offline   Reply With Quote
Old 09-08-2003, 04:53 AM   #14
yukionna
yukionna's Avatar
Images: 18
I'm wondering now if I should install a bracket to help support the plumbing.
It would be great if someone could post a close-up photo of their bracket.
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 08:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 12:13 PM
holding tank question.. Morning Dew Waste Systems, Tanks & Totes 1 03-19-2004 04:44 PM
Holding tank Question GOTPIKE All Argosy Trailers 4 08-20-2003 10:35 AM
General plumbing question eracism Fresh Water Systems 2 01-14-2003 07:41 AM
