08-15-2014, 07:51 AM
1973 31' Sovereign
Kettle falls
'73 Sovereign water leak
I have water leak at both front corner windows. The top of them are sealed good wonder if the seal that holds glass in looks to have shrunk over the years . Remove it and caulk or ? Also my 73 has 6 inch frame in rear and a smaller frame under that. Must have been updated I think ? Was worried about frame separation but looks good I think .
08-15-2014, 07:57 AM
1976 25' Tradewind
A lot of people with that leak vulkem the inside of that window on the old seal after cutting the old seal flush with a sharp knife. Seems to work for them. Mine leak too and that's my plan.
76 'Airstream Tradewind
Matt
08-15-2014, 08:13 AM
1981 31' Excella II
New Market
, Alabama
Cut the exposed portion off with a utility knife then clean everything real well then use the Trempro-635 or similar urethane to caulk that area between the glass and the frame. This is where the water gets between the panes.
Perry
08-15-2014, 08:17 AM
1973 31' Sovereign
Kettle falls
Thank you for the information I didn't I think it was the top window as someone has sealed the roof with a thick rubberized coating before I bought it
08-15-2014, 08:19 AM
1981 31' Excella II
New Market
, Alabama
As far as the rear end separation issues go you need to inspect the floor in the bathroom. Also look at the rear cross member and see if it is rotted out. The area where the plate that holds the bumper compartment goes under the trailer has killed more Airstreams than anything else.
Perry
08-15-2014, 02:10 PM
1973 31' Sovereign
Kettle falls
The bathroom floor is perfect condition I just replaced all the flooring and it looks great . Can I look at the rear crossmember from above or do I have to take the metal off the bottom or the holding tanks are?
08-15-2014, 02:13 PM
1973 31' Sovereign
Kettle falls
so far it isn't sagging at all it was under a pole building with the frame supported in 10 different places for the last 25 years I realize I'll probably need axles
08-15-2014, 05:20 PM
1981 31' Excella II
New Market
, Alabama
The the bumper compartment should give you acess the crossmember.
Perry
08-16-2014, 08:27 PM
1973 31' Sovereign
Kettle falls
Thanks Perry. Ill check her over.
08-26-2014, 10:13 PM
1973 31' Sovereign
Kettle falls
So... Looking in year compartment I don't see much ? The frame looks ok no rust, there are no cross members other than two angle iron pieces that hold in sewer tank ? Can't see more foreword than that. Wonder if I should remove under belly and look further ?
1973 land yacht international sovereign
