Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 08-14-2006, 12:13 PM   #1
1966 17' Caravel
Seattle , Washington
Send a message via AIM to kitchenclose
Window repair for Caravel
Greetings Airstream Lovers!
I have a project to reseal / repair my windows on a 1966 Caravel. Besides removing all the silicone and dirt. What should my steps be?
All the windows are in great shape - Do I need to remove the window before laying down the window gasket? (The rubber strip which sticks on the Airstream and the window lays on)
Is there window gasket in the hinge?
Here's some pictures which may help explain my to-do project.
Thanks for your suggestions.
K
ID:	24691   Click image for larger version
ID:	24693   Click image for larger version
kitchenclose is offline   Reply With Quote
Old 08-16-2006, 11:25 PM   #2
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Did you get this figured out yet ? My 65 Caravel is completely different. I have no experience with your type of windows.
Is the window removed in the pictures ?
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 08-17-2006, 07:05 AM   #3
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
There are several threads in the forum on putting down new gasket material for this particular style of window. Short answer, DON'T remove the glass, you can't really anyway without possible destruction. I will check to see if I have (original) gasket up top.
There IS a description, from Andy at InlandRV, about how to weather seal the hinge.
Get rid of the silicone and never use it. Get Trempro or the newer stuff from vintagetrailersupply.com, I'm thinking using the faster stuff will work, and run a bead along the very top of the window frame, where the skin meets the frame, and smooth it down with your finger. That will seal the window frame. Water coming in the hinge is the next problem addressed above. Put down new gasket, which I don't have experience in, then lubricate it with silicone spray. That's it!
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 08-17-2006, 10:48 AM   #4
1966 17' Caravel
Smile
Thanks guys for your replies. I did find the window threads and did read them. I'm taking this project slow as I do not want to break the glass.
Cheers
K
Old 08-17-2006, 03:28 PM   #5
1963 19' Globetrotter
Orion , Illinois
Unless you like the sound of breaking glass don't take out any window you don't need to. Check with Vintage Trailer Supply for seals and gaskets, they probably have everything you need . I redid the windows on my '63 with their products and could not be happier with the results. They use a silicone type material to manufacture their products and it does not shrink or compress once installed, plus it looks really good. Red Devil makes a grey silicone cualk that matches it perfectly when sealing the corner joints.
I always carry extra seal , glass bead ,and bedding tape with me in case I need to repair a broken window when on the road.
63air is offline   Reply With Quote
Old 08-17-2006, 04:53 PM   #6
Cheers
K
The original window gasket is available from a few dealers.
Do not remove the glass.
Remove the old gasket and adhesive completely, then clean the surface with alcohol.
Apply Super weatherstrip adhesive to the back of the gasket, and to the window frame. When the adhesive is dry to the touch, which takes about 5 to 10 minutes, apply the gasket with the double flange facing outward.
Do not stretch the gasket, and do not mitre the bottom corners.
That same gasket is used on your entrance door and access compartments.
Do not use any yellow adhesives.
Andy Rogozinski
Inland RV Center
Corona, CA
caravel
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
