water in belly pan leaked some water...in the back
So I just returned from a long weekend,, and I could use some advice. 2008 25ft, Safari SE. As I was pulling out of the site today... I had a bunch of water running out of the belly pan, on the opposite side of the back sewer plumbing.... Now a couple of things happened before. One, we had strong down-pours all night,,,,, I checked every corner and nook in the AS, and found no water on the floor, inside the AS. Secondly, I blasted water into the black tank, through the Flush hook-up, to clean it out, just prior to leaving....
I am suspecting the BlackWater tank flush connection has a leak some where before it goes into the tank??,,,,,but I am too new to this AS stuff, so I could use some wisdom,,,,, Thanks in advance
