Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 04-13-2017, 02:38 PM   #1
2015 27' FB International
Erie , Colorado
Sea level II Monitor
Our SeaLevel II tank monitor is giving an error message (OPn) for all three tanks (fresh, grey & black). Research has indicated this could be one of two problems: a ground wire disconnect at one of the three monitors or a bad monitor. Does anyone have any experience with this issue
Rockhound100 is offline   Reply With Quote
Old 04-13-2017, 02:42 PM   #2
runnersg's Avatar
2016 27' Eddie Bauer
TX , Texas
I had some weird stuff happening with mine a few months ago and it was a simple fix. The neutral was not well connected in the panel. It wasn't obvious and I would've never known to look there had it not been suggested by another. Kill power to the trailer, go to bus bar in your panel, it should be right up front and easy to access. All I did was to make sure that each neutral wire in the panel was well connected. No point in trying to figure out which neutral goes to the SeaLevel. Just check them all. It fixed it and never another issue since.
2016 Eddie Bauer 27'
runnersg is offline   Reply With Quote
Old 04-14-2017, 10:19 AM   #3
Erie , Colorado
Thumbs up SeaLevel II Monitor
Runnersg
Thanks for the tip. Can you be more specific regarding the location of the bus bar that you are referring to. A photo would be helpful if you have one.
Thank you
Old 07-07-2017, 01:11 PM   #4
2017 16' Sport
Portland , Oregon
Me Too
Were you able to sort this out? I'm having the same issue and not at all familiar with the mechanics of this trailer yet. It's brand new and only been on 3 short trips so far. I was having power issues on the last one, which was off grid, and noticed that my grey/black tank was not ever reading above 0. I brought it back home and charged it up only to then see the "OPn" readout on the monitor afterward. Not sure what's happened.
Holly
polyester is offline   Reply With Quote
Old 07-07-2017, 01:17 PM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Originally Posted by Rockhound100 View Post
Runnersg
Thank you
Hi
The neutral is part of the master electrical panel. You have three basic wires for each 120V circuit: hot, neutral, and ground. For a 240V circuit, you add a second hot lead. A cheap plug in circuit checker from Home Depot will give you a good idea if things are hooked up.
Old 07-07-2017, 01:27 PM   #6
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Uncle Bob,
My panel is 12 vdc, although I predate the SeaLevel. I would guess the earlier poster meant to say ground bus.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-08-2017, 08:17 AM   #7
Half a Rivet Short
2022 Interstate 24X
Originally Posted by lsbrodsky View Post
Uncle Bob,
Larry
Hi
I suspect they did ...
No kidding. How level is level? upnorththree Towing, Tow Vehicles & Hitches 19 03-25-2017 01:14 AM
Sea Level to High Elevation: Look Out! Ray Eklund On The Road... 21 09-15-2016 10:15 PM
sea level II Drplate General Repair Forum 0 11-09-2015 08:02 PM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
