Old 06-30-2017, 12:42 PM   #1
1979 23' Safari
Redmond , Oregon
Fresh water drain
I have a 1979 Airstream and I need to replace the Fresh Water drain tank (male threads) to the tank. The old plug was roughly 1.5 to 2 inches in diameter. Any suggestions on where to find one.
Thank you,
Blake
oregnelk is offline   Reply With Quote
Old 06-30-2017, 02:23 PM   #2
1979 23' Safari
Wayland , New York
Thank you,
Blake
Are you talking about the big one that goes in the bottom of the tank and not on the side?
It's probably either 1-1/4 or 1-1/2 mpt. I found replacement for mine at tractor supply on the tank fitting section, pretty sure mine was 1-1/4.
Unfortunately it was shaped like a cup which means it would always hold water. I was worried about water in it freezing and cracking the tank so I drilled a small hole in the middle, put a stainless screw up through the bottom and filled the cup with melted (non toxic) hot glue. I made the large amount of hot glue by melting it in a container in a 400F oven and pouring into the plug.
Old 06-30-2017, 04:25 PM   #3
1979 23' Safari
Redmond , Oregon
Mine is the black plug with male threads at the bottom of the tank.
Old 06-30-2017, 07:16 PM   #4
1979 23' Safari
Wayland , New York
Mine was a white(originally) plastic plug. Trick is simply finding one that fits the threads and is pretty flush on bottom so it can fit in the pan. The replacement I found was nylon with a big flat hex head.
Old 07-02-2017, 11:39 AM   #5
1979 23' Safari
Redmond , Oregon
Where did you find the plug. Or, any suggestions.
Thank you,
Blake
Old 07-03-2017, 09:13 AM   #6
1979 23' Safari
Wayland , New York
Thank you,
Blake
I found something that worked at tractor supply. Not sure if you have that where you are, a different branch supply might have them as well. It was a nylon hex plug meant for farmers to use on their big ag tanks.
I'll get a picture today. I might have an extra in one of my bins.
Joe
Old 07-09-2017, 07:16 AM   #7
1979 23' Safari
Redmond , Oregon
Fresh Water Drain
Thanks Joe.
The one I lost was black about 2 inches in diameter and had a socket for a large hex head "allen wrench" tool.
Blake
Fresh water tank drain valve location? trilink3 Fresh Water Systems 11 04-29-2024 08:12 AM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
fresh water drain: broke it off. help jpar Fresh Water Systems 12 10-07-2009 06:20 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
