Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 06-15-2009, 09:16 PM   #15
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Originally Posted by rustyrivet View Post
Thank you all. This is very confusing. I bought my Airstream Safari used (2005 model). I have never had to change any of the pipes; water or propane. I assumed, perhaps incorrectly, that the PEX pipe to the propane tank was factory installed by Airstream. Some on the forum say they have replaced their systems with pex and others say it is a definite no-no. The quote by 2daBeach, from the SharkBite manual sounds very definitive. I may need to run an entirely new copper propane line. I am going to contact Airstream and see if PEX was factory installed for propane on 2005 Safari's.jc
PEX is for water only. Propane should be copper or in some cases black iron pipe. Copper preferred and it is what AS uses from the factory. There are a some rubber hoses used at the regulator (from the tanks to the regulator).
Aaron
WBCCI #2449 AIR #2495
Old 06-17-2009, 03:41 PM   #16
rustyrivet's Avatar
Profile:  2005 22' Safari
Gresham , Oregon
Just received a response to an e-mail that I sent to the Airstream website regarding the use of Pex on the LP line in my Safari. They indicated that they surround copper pipe with the flexible water pipe (PEX) to protect it from rocks and other road debris. The propane is carried through the copper pipe. The Pex is simply for protection. I'm not sure when they started doing this but am relieved that I don't need to replace my LP lines. Thanks for all the advice. I feel safer already. jc
rustyrivet is offline   Reply With Quote
Old 06-18-2009, 02:40 PM   #17
Profile:  1972 29' Ambassador
Harrah , Oklahoma
Lowe's now sells a competing product they've cleverly named 'Gator Bite' if you can't find the Shark Bite product in your area. It works the same and connects your pex to coppor, butyl, pvc, etc.
My Brain Project and Tech Notes
airbassador is offline   Reply With Quote
Old 06-18-2009, 02:44 PM   #18
Harrah , Oklahoma
That's actually a really good idea, as the pex would give it quite a bit of protection. I think I'll do that as I'm about to run some new propane lines on my old Ambassador.
I seem to remember Andy @ InlandRV saying something about using foam insulation for the same purpose, but I'm not sure because he may have just been yelling at someone to replace their !@#$ axles and I ignored everything else (Just kidding Andy... I need axles and will be ordering them soon!).
Old 06-18-2009, 06:46 PM   #19
76sovereign's Avatar
Profile:  1976 31' Sovereign
ozark , Missouri
Be careful after the repair to check the lines with air. If it holds 40lbs pressure for 10 mins you're good to go.....
What we found was after fixing the obvious and hitting it with air pressure we had many more leaks that were in impossable place to reach.
Good luck to you
http://airstreamremodel.blogspot.com
http://vimeo.com/kani
76' 31' Sovereign
76sovereign is offline   Reply With Quote
Pex Connector Question Jim & Susan Fresh Water Systems 9 03-03-2009 07:28 AM
Pex line and flair-it fittings question Frieberg Plumbing - Systems & Fixtures 3 10-13-2008 08:40 PM
Re-plumbing 1/2 or 3/8 PEX Gen Disarray Fresh Water Systems 5 03-04-2007 09:52 PM
Per-PEX-ing Question soldiermedic Fresh Water Systems 19 11-07-2006 09:13 AM
PEX Plumbing on DIY GlenCoombe Fresh Water Systems 6 08-06-2006 01:54 PM
