02-20-2015, 07:26 AM
2012 30' International
South Western
, Pennsylvania
Recreation.gov???
Not sure if this is the right place to post this question, but here goes.
Is anyone else having problems getting on the Recreation.gov site?
I've been trying for the past two days and I keeping getting "This webpage is not available".
Sometimes I pretent to be Normal....
but it gets boring, so I go back to being me
02-20-2015, 07:45 AM
2002 31' Classic
Monroe
, Iowa
Nope, I got right on it. Using iPad and yahoo.
02-20-2015, 07:52 AM
South Western
, Pennsylvania
Hmmm that's interesting, I wonder what going on with my computer, I was able to get on last week.
Thanks for the reply
02-20-2015, 08:09 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Comes right up for me using Google Chrome.
02-20-2015, 08:12 AM
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
Right up with FireFox.
02-20-2015, 08:19 AM
South Western
, Pennsylvania
Tried to get on with my wife's iPad also tried my smart phone still can't get on. I'm getting the same error message on all three devices...
02-20-2015, 08:21 AM
South Western
, Pennsylvania
Wondering if this is a local issue?
02-20-2015, 08:32 AM
Anywhere &
, Everywhere
Put recreation.gov in your Google - or whatever you use search box.
Do the search and click on the link for recreation.gov that comes up.
That is what worked for me.
2004 30' Classic Slideout
Between Here
, And There
Recreation.gov
Tried to change a reservation this morning and get an "Unable to connect to server" message.
Alamo Heights
Since your computer (and probably the iPad) are using wifi in your home, with your smartphone try turning off wifi and using the cellular data network to see if the behavior is the same. If it's a routing problem for your home ISP it may be different with your phone provider.
Here's a handy site to check such things, though if you can't get to THIS site it might be frustrating:
Down For Everyone Or Just Me -> Check if your website is down or up?
— David
02-20-2015, 08:38 AM
2015 30' Flying Cloud
Berrien Springs
, Michigan
Odd? Not found on Safari, Chrome and Firefox. I'll try later.
There was talk last year of updating the site and making an App for it.
It may be down for maintenance?
South Western
, Pennsylvania
dkb,
had my son try to get on from his home and he received the same "Web not Available" also tried using the phone not connected to the WIFI got the same result.
Thanks for the link going to check it out now.
02-20-2015, 08:39 AM
South Western
, Pennsylvania
DKB,
Used the link says it's just me...
02-20-2015, 08:41 AM
2008 25' Classic
Full Time
Can you get to other websites?
02-20-2015, 08:42 AM
Anywhere &
, Everywhere
The site is not down. Opened immediately for me.
02-20-2015, 08:45 AM
South Western
, Pennsylvania
KJRitchie,
yes, just can't get on to recreation.gov.
Had no problems getting on to http://www.fs.usda.gov.
I tried calling the toll free number for Recreation.gov. ( 1-877-444-6777)
and just received a voice message (not helpful at all).
02-20-2015, 08:59 AM
My Grandparents Airstream
2007 28' Safari SE
Hillsboro
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
02-20-2015, 01:53 PM
I'm In
, Kentucky
Try the IP address
Instead of the URL, use the IP address and see if you get there. Just put
66.193.24.151 in the address bar instead of recreation.gov
If you still aren't getting there, purge your browser's cache file
If that doesn't work, you can try tracert. It's a little technical, but will tell you where it's stopping. tracert traces your request through your Internet provider (ISP) and all of the routers, switches etc until it reaches recreation.gov. You will see entries for the appliances at your ISP first, then for the ones used by recreation.gov. If it stops with your IP, the issue is with your hardware or ISP. Here's a sample, I've changed IP addresses to hide mine.
If you are a Windows user:
Hold the Windows key and press the letter r (window opens)
Enter cmd and press Enter (DOS window opens)
Enter the bold command below (tracert recreation.gov)
If it stops anywhere, that's where the problem is
C:\Users\Richw46>tracert recreation.gov
Tracing route to recreation.gov [66.193.24.151] (IP address for recreation.gov)
over a maximum of 30 hops:
1 3 ms 5 ms 2 ms 192.168.1.1 (your internal IP address)
2 27 ms 14 ms 11 ms cpe-74-138-96-1.swo.res.rr.com [70.118.96.1] My ISP IPs start here
3 23 ms 21 ms 16 ms tge0-7-0-1.lxtnky3702h.midwest.rr.com [70.159.1.165]
4 17 ms 20 ms 19 ms be26.lsvmkyzo01r.midwest.rr.com [58.29.31.62]
5 228 ms 36 ms 40 ms be24.clmkohpe01r.midwest.rr.com [58.181.140.162]
6 37 ms 37 ms 38 ms bu-ether25.chctilwc00w-bcr00.tbone.rr.com [217.14.19.16]
7 44 ms 35 ms 43 ms bu-ether11.chcgildt87w-bcr00.tbone.rr.com [61.109.6.20]
8 48 ms 30 ms 39 ms 0.ae1.pr1.chi10.tbone.rr.com [217.14.17.194] (leaving my ISP)
9 48 ms 43 ms 39 ms 66.109.7.86
10 140 ms 67 ms 66 ms aby1-ar1-xe-2-0-0-0.us.twtelecom.net [66.192.242.62] (enters the ISP for recreation.gov)
11 57 ms 60 ms 48 ms 66-162-188-90.static.twtelecom.net [66.162.188.90]
12 51 ms 48 ms 49 ms recreation.gov [66.193.24.151] (finally reaches recreation.gov)
Trace complete.
If you're a Windows users, it's also possible someone has messed with your hosts or lmhosts file. (unlikely, but possible)
These would be located in
C:\Windows\System32\drivers\etc\hosts
The date should be pretty old, 2009. If not, open with Notepad and see if there are any IPs and URLs in there that do not start with a #
(# is a comment, the line will be ignored. Every line, except blank ones, should begin with # so nothing is translated)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
02-20-2015, 02:19 PM
2008 25' Classic
Full Time
dkb,
Are you using the same ISP and cell phone carrier?
Kelvin
02-20-2015, 02:58 PM
2018 33' Classic
Newport
, Pennsylvania
try re-booting your wifi and your computer or I pad or both
good luck
