... Should I tell the shop that the police are coming?
there is no tactical reason to inform them...
many negatives IF you do...
-further work is done...
-or completed work is UNDONE...
-parts go missing...
-bits are damaged...
-the unit gets moved off site...
-shop closes for the day...
and so on.
yes this is a confrontational event, but does not have to be negative or deteriorate.
having a neutral party with authority present helps with your primary goal...
to reclaim your property with little drama or risk....
and get away cleanly....
cheers
2air'
and i still think you should bring a camera....
__________________ all of the true things that i am about to tell you are shameless lies. l.b.johnson
When we arrived, the shop had already move the trailer out of the shop as well as two piles of parts around the shop. The stuff I told them to throw away weeks ago was there too, and I was mandated by the police to take it with me. Needless to say I did not have room, and some people had to make a trip to the dump.
I was mad that when I was finishing loading my gear I asked the police office to ask the shop worker for my $100 piece of marine plywood that was to be used for the job. The officer came out and told me that the shop said they had accidentally broken it while setting the shell on the frame. Give me a break,, how does one break plywood placing a shell on it? I think they wanted an extra $100 for their botched job. The police said that even though I signed the form they wanted that I had grounds to sue them in civil court, and that their paper didn't mean anything. Not sure if I agree.
The way we rigged the shell to the frame worked very well considering the rear channel and front channel were not bolted down at all. I had no sway at all, but the road bumps were a little more than I liked (Rail road tracks).
I will be parting out the interior for what I can get for it, and then sell the shell/frame as a project for someone or as scrap.
What a drag. What jerks. I can't believe you had to go back in there and pick up all the itty bitty pieces of your trailer. I don't understand how people can stand to behave so poorly. You're mechanic sounds just plain mean. I don't have any other words to describe it. As a good friend of mine said the other day, people can only beat the system for so long. It does come back to them. I'm so sorry you had to go through all this. It sounds like even the police were sympathic.
M.W.
"You just have to decide if you’re a Tigger or an Eeyore." - Randy Pausch
Good job Steve. The guys history, and you are so much smarter. Remember, education is not free. Good times ahead, and my the stories around campfire. I glad it's behindl you.
My Airstream needs one too, but for totally different reasons....
i would have just left it there...let him suck up the space, time and money....when finished....i would have been like...so long i forgot about it...keep the 1300 as a learning experience....
sometimes i have learned to loose a little before losing a lot...1300...i would have passed on....and stuck him with a trailer that you were likely going to scrap anyhow...
I'm sorry your experience was so negative, the way in which you were treated was so wrong. It sounds trite but its only money, only stuff. In the end it is their loss in reputation and integrity. Behavior like their's has a way of coming back around to them. What you sow you shall also reap.
Originally Posted by soldiermedic
Just got in and showered from the ordeal . . . .
That even sounds metaphorical. Wash them off your skin, out of your hair, way way out of your life. DONE!
Wash as in it was over 90 degrees that day, and I was inside an aluminum oven with no insulation to keep out the heat
I know your on the road now, but WOW I am truly sorry for the ordeal you had to go through!! My prayers are with you on the road and down the line as you embark on your new Airstream adventure. You really need to get out and camp as soon as possible!!!
Tedd Ill
AIR#3788, WBCCI#4028 Membership discontinued
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
