Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 12-27-2015, 06:24 AM   #81
Ray,
Here's an ebay auction for a Teleflex speedometer. I can't guarantee that it's the same as used in most of the Classics but it has the same part number as the one I pulled from the 345 that I dismantled.
I bought one just like it but since my Argosy is a long way from being on the road I have no idea if it will work correctly or not.
I have no idea why yours doesn't have a trip odometer, that seems pretty unusual to say the least.
1975 24' Argosy Motor Home
Old 12-27-2015, 06:35 AM   #82
Originally Posted by tjdonahoe View Post
Want to spend money? Digital outside air temperature gauge, rear axle temperature gauge ,maybe an exhaust temperature gauge......
I do like the idea of the rear axle (diff) temp and the exhaust temp gauges!
To bad Teleflex doesn't make them in the XL style.
Old 12-27-2015, 10:42 AM   #83
I am still trying to figure out the air speed indicator... It would be interesting to know what the headwind is!
But I also like the idea of adding a tach, oil pressure, and temp gauge for the genset.
Old 12-27-2015, 01:13 PM   #84
Bethany533's Avatar
1983 30' Airstream 300
Covington , Louisiana
Thanks Brad.
That one is close, but mine uses a clip to hold the drive cable on. If I can squeeze under the dash, I'll post a pic.
Bethany533 is offline   Reply With Quote
Old 12-27-2015, 03:12 PM   #85
Originally Posted by Bethany533 View Post
Thanks Brad.
Dang, I missed that!
PM me your mailing address and I'll send you one to try.
Old 01-05-2016, 05:40 PM   #86
1995 36' Classic 36
Ludington , Michigan
How can you drive without this engine instrument!
Name:	ImageUploadedByAirstream Forums1452040806.763293.jpg
Any guesses?
Kota is offline   Reply With Quote
Old 01-05-2016, 06:00 PM   #87
Well, I've not found one of those lurking in my Argosy so I'm assuming it was only issued with the Classic's....
Old 01-05-2016, 06:05 PM   #88
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Attachment 255194
Any guesses?
Looks like 1 horsepower to me...
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 01-05-2016, 06:05 PM   #89
1995 36' Classic 36
Another hint!
Name:	ImageUploadedByAirstream Forums1452042346.989685.jpg
Old 01-05-2016, 06:41 PM   #90
1995 36' Classic 36
Name:	ImageUploadedByAirstream Forums1452044445.239036.jpg
About 60 years ago a parts salesman used to stop by my dad's shop to replenish oil, wiper blades, filters, mufflers, etc... He gave out novelty samples occasionally.
This little horse sits on your dash. The hose connects to the intake manifold. The diaphragm pulls the strings causing the horse to perk up as the vacuum increases. Best economy comes when the pony is erect and stiff.
Old 01-05-2016, 06:53 PM   #91
I'll take TWO!!!
Old 01-05-2016, 08:08 PM   #92
Now THAT is funny!
Old 01-06-2016, 05:03 AM   #93
Airstream Driver
1994 30' Excella
Images: 49
need my mailing address to send me the winning price ?
AIR #13
Old 01-06-2016, 03:40 PM   #94
1995 36' Classic 36
Name:   ImageUploadedByAirstream Forums1452120023.906391.jpg
http://pomsiespushpuppets.blogspot.c...nd-engine.html
Old 05-21-2017, 06:46 PM   #95
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I wonder if this would work Charly.... Oil pressure gauge, so runs from a sender, and reads to 90psi....
I think I might grab one and try it as a Fuel pressure gauge...
Teleflex Oil Pressure Gauge 0 90 PSI Part 54658 | eBay
Added this to my gauge setup(temporarily installed).
Innovate Fuel/Air gauge.
Keyair ,
How do you like your A/F gauge now that you have had a chance to use it? I am going to add one to mine. Would you buy the same one again if you had the choice?
Gregsch is offline   Reply With Quote
Old 05-22-2017, 08:59 AM   #96
Wayne, I opted to use an AEM 30-4110 wide band O2 A/F gauge. I'm not sure about other gauges but this one was recommended to me by my TBI tuner because it can be connected to the PCM which allows the WBO2 reading to be logged.
AEM 30-4110
Name:	aem o2 gauge.jpg
Name:	test stand with wbo2 gauge.jpg
Old 05-22-2017, 10:43 AM   #97
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Hmmm....can I connect that to my TBI PCM and monitor it while driving down the road?
Boom Sounds is offline   Reply With Quote
Old 05-22-2017, 11:41 AM   #98
Nick the short answer is it wouldn't really do anything for you to connect it to your PCM, for monitoring purposes you just need the gauge. The long answer is my tuner wanted to have the WBO2 sensor output logged with all the other data was so when he makes tuning adjustments to the PCM code he can see what all of the other variables were doing at the same time. To log the WBO2 data he had to add code to the PCM to get it to log properly.
The PCM itself does not use the WBO2 data at all, it will only use the Narrow Band O2 sensor for fuel mixture adjustments.
On a side issue I also had him add in an output that will turn the radiator cooling fans on when the coolant temperature gets too high. That negated the need for me to add a separate temperature controller for my electric fans.
Old 05-22-2017, 06:58 PM   #99
Gregsch's Avatar
Tipp City , Ohio
AEM 30-4110
Attachment 286059
Thanks Brad! If that's what you bought that's all I need to know. I know you always do all the research that's needed and then some. I am planning on rebuilding my Quadrajet and I want to establish a base line before I get started. I will let you know how it turns out.
Old 05-23-2017, 12:02 AM   #100
Thanks Brad, I almost understood that!
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
2003 Airstream Classic 30 Ft. EXCELLENT!!!! S2003 Airstream Classic 30 Ft. EXCELLENT! eBay Watch Airstreams on eBay 0 09-12-2011 09:50 AM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 08:32 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 08:33 PM
Classic Airstream Motor Home T-shirt and gift items maltnhops Classic Motorhomes 0 03-18-2011 11:10 PM
