Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 05-10-2019, 10:31 AM   #1
1984 31' Airstream310
Ware , UK
Front banana panels for 310 Classic.
is it realistic to think I'll find a supply of the Front banana for a 310 Classic Motorhome or are we all now down to repair only?
Oh and just to complicate matters on such a large an unusually shaped object, I'm in England ...... (although could ship to a US address for forwarding).
have sent an email (and tried calling) Airstream Supply without success. Anyone recommend any other suppliers / source??
thanks all
cheers
V8JET is offline   Reply With Quote
Old 05-10-2019, 10:41 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
thanks all
cheers
Inland RV has them but getting them overseas will be fun. https://inlandrv.com/product-category/motor-home/
Cheers, Dan
~ Margaret Thatcher ~
Old 05-11-2019, 12:08 PM   #3
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
You know, you could make them yourself for about 75.00 used. Make a concrete form, and lay down some fiberglass mesh. Make it about a1/4 inch thick, and your good to go. They're pretty pricey, for what they are. I may do just that, come winter. My back wraps are broken, right on the top edge. All there, just split. I tried heat gluing them. That made them more brittle. So for now, gorilla tape. Good luck DJ
davejay is offline   Reply With Quote
Old 05-11-2019, 12:18 PM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I believe Inland RV got the molds after Airstream threw them out, and are now re-creating in fiberglass rather than ABS.
The last ones I got from Airstream Supply were actually for the post-92 model with the chin spoiler and fog lights, as being used on Peanut's thread. It's not an easy change - ask Ernie!
MEK/ABS granules and repair yourself providing you have the remains of the originals.
Or you could build in alumin(i)um as Keyair is doing.
martin300662 is online now   Reply With Quote
Old 05-12-2019, 08:39 AM   #5
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Add fiberglass mat in the mix for more strength to the repair.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Old 05-13-2019, 02:44 AM   #6
Ware , UK
Thanks guys for both supplier and suggestions. Good to know I can get them but as Smartstream says, getting them to UK will be fun and costly.
As mine are intact but cracked and brittle, I will see if I can create a replica first out of fibreglass.
If that doesn't work I'll be onto InlandRV. in Winter.
Thanks all again, really helpful
cheers
Trouble removing front banana wraps Cochese Ribs, Skins & Rivets 4 12-31-2016 07:31 PM
front banana wrap! kokomoscalls Ribs, Skins & Rivets 1 02-06-2014 05:53 AM
Front Banana Wrap Replacement Gkiesel Belly Pans & Banana Wraps 5 07-08-2008 05:30 PM
72 Safari Removing Banana Wrap in front of battery compartment Tom Bray Belly Pans & Banana Wraps 2 08-27-2007 11:55 AM
