Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1960 - 1964 Overlander
Old 01-31-2010, 09:14 AM   #1
3streams's Avatar
1948 22' Liner
1949 24' Limited
Springs , Pennsylvania
Exclamation Need 1961 Wiring Diagram!
We need a copy of the 1961 wiring and electrical diagram- if anyone has one please post it. Thanks!
April & Andy Hershberger
www.ClassicAluminumTrailers.com
3streams is offline   Reply With Quote
Old 01-31-2010, 09:20 AM   #2
Retired.
. , At Large
Unless somebody has taken apart their trailer and mapped the wiring, there isn't one. It's almost like they put the wires where they wanted to on that day, and it's different from the Ohio factory to the California factory as well. Is there any one thing you want to know where it should be routed?
Old 01-31-2010, 11:11 AM   #3
2008 16' Safari
Destrehan , Louisiana
You really don't need one. The wiring is simple and straight forward. If you're refurbing the trailer you will want to update the wiring. You can find diagrams for later model trailers. Use that as a referance point for the wiring. You can add or delete circuits as you like. Just make good notes and draw a good diagram when you're done.
dlb435 is offline   Reply With Quote
Old 01-31-2010, 11:57 AM   #4
3streams's Avatar
1948 22' Liner
1949 24' Limited
Well, our battery stopped charging. So I checked the new power inverter and it seems alright. no fuses blown and the wires are all attached. Next I thought I would check the suspect pigtail and the wiring under the belly pan where it connects to the trailer wiring. What a mess! I purchased a new pigtail and a 7 way wiring box from VTS to keep the wiring connections out of the weather and rule this out as a problem but the wires connect to others not of the same color. So I will post a picture of what I am speaking of.
The second thing that is complicating things is a third set of wires that connect in at the junction. I am thinking these are trailer light wires? The White from the pigtail and trailer attach to the green wires from this third set. I guess my biggest worry is that if I change the wiring to match colors something is not going to work. But this probably needs to happen to straighten the wiring out. Any input on what I'm looking at is greatly appreciated.
ID:	95138   Click image for larger version
Old 01-31-2010, 06:34 PM   #5
2008 16' Safari
Your trailer was rewired at some point in the past. There will be no wiring diagram, you're on your own here.
Old 01-31-2010, 06:44 PM   #6
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Do any of you guys use "hound dog" type tone generators to trace wires? I have the same problem as my trailer seems to have been re-wired ('69, all copper, I'm glad, as I've heard the original had aluminum..). A friend recommended the tone generator as the best affordable way to map out what goes to what so I ordered a Triplett kit for $50. I'm hoping this begins to provide some insight....
fotochop is offline   Reply With Quote
1961, electrical, wiring
wiring diagram banjoman Vintage Kin 2 07-23-2008 05:03 AM
wiring diagram banjoman Electrical - Systems, Generators, Batteries & Solar 1 07-20-2008 10:14 PM
Wiring diagram 2Coaster 1970 - 1973 Overlander 9 04-13-2008 07:48 PM
wiring diagram frederic.c01 Electrical - Systems, Generators, Batteries & Solar 1 05-30-2004 01:59 AM
wiring diagram? nu2argosy Electrical - Systems, Generators, Batteries & Solar 2 04-20-2004 07:30 PM
