Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 04-07-2021, 06:50 PM   #1
Backfortyjoe's Avatar
2019 20' Flying Cloud
Eau Claire , Wisconsin
City water problem.
It appears that the City Water is running into the fresh water tank. Any one with an idea on this? I believe I have seen it here somewhere but can’t find it now. It’s a 20’ 2019 FC FB. Thank you for any and all help.
Backfortyjoe is offline   Reply With Quote
Old 04-07-2021, 07:01 PM   #2
Sag Harbor , New York
Probably because the check valve in your pump has some grit in it, or simply failed, allowing city water to flow backwards into the water tank IMO.
"pump bad check valve tank filling" --
https://www.google.com/search?q=pump...=airforums.com
Many of these threads, and similar ones, are in the Fresh Water Systems forum: https://www.airforums.com/forums/f443/
You should always use an inline RV filter in the hose, both when filling the tank, and when on city water, especially if your water source is from a well.
Turn off the city water, use the tank water, and turn the pump on and off a dozen times or so [with a faucet open] . . . usually the grit will clear out on its own. You may have to replace the check valve or pump if the problem does not resolve itself. You might also want to check all your faucet aerator filters for grit. One bad batch of water, from the back forty, can clog up the works all over.
Good luck.
Old 04-07-2021, 07:17 PM   #3
City water problem.
Good luck.
Thank you for your quick reply. I always read your advice, you seem to know your way around the FC very well. Do you know the best and easiest way to get at the pump? Do I need to remove it to get at the check valve? On the 20’ model, where would I install accumulator? Lots of ??? Joe
Old 04-07-2021, 07:21 PM   #4
Thanks, but this seems to be a fairly common problem in any trailer with a water pump . . . . . . as those search results show.
Old 04-07-2021, 07:47 PM   #5
Originally Posted by Backfortyjoe View Post
. . . Do you know the best and easiest way to get at the pump? Do I need to remove it to get at the check valve? On the 20’ model, where would I install accumulator? Lots of ??? Joe
The pump is curbside under the stove in our 2014 . . . remove the big drawer and have at it. Not sure about the check valve.
Accumulator under the bathroom sink, in the 20-footer thread here. [hot link in blue]
[shutting down for the night]
City water connection problem Martin R Fresh Water Systems 13 11-28-2015 09:53 AM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
59 Tradewind 'City Power' electrical problem xposure285 Electrical - Systems, Generators, Batteries & Solar 20 07-16-2009 10:13 AM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Connected to city water...NO WATER! Sovereign86 Fresh Water Systems 7 06-13-2007 12:00 PM
