05-29-2023, 11:00 AM
2019 23' Flying Cloud
Waterford
, New York
Changing from AGM to Lithium batteries
I have a 2023 flying cloud that came with AGM batteries and I considering changing to lithium. The charger auto detects battery type. I need to change switch settings on solar control and I buying self heating battery’s so they can go outside. Anyone see a problem with this plan? Do I need to change anything with charge lead from truck?
Regards,
Larry
05-29-2023, 08:15 PM
1988 32' Excella
Robbinsville
, New Jersey
Well your stock converter with auto-detect is questionable whether or not it will work properly, many have had issues getting it to work right and keeping it working right.
For the charge line from the truck you would be better off if you either disconnect it or add a DC to DC charger, some do both with adding separate wires for the DC to DC charger.
05-30-2023, 06:47 AM
2022 27' Globetrotter
Bethlehem
, Pennsylvania
+1 about the WFCO converter. In theory you won’t need to buy a new converter, but I would recommend that you include a Progressive Dynamics replacement in your budget. The WFCO units don’t like to go into and stay in lithium mode. WFCO Will upgrade the firmware for you if you jump through lots of hoops, but it likely won’t permanently fix the issue with the converter.
05-30-2023, 02:24 PM
2018 27' Flying Cloud
Atlanta
, Georgia
What he said.
05-30-2023, 06:26 PM
Waterford
, New York
Originally Posted by jnm30327
What he said.
I will look into progressive dynamics. Look as the dc to dc chargers, I’m thinking 20 amps is sufficient and I don’t know if the wiring on the truck will supply much more than that.
06-02-2023, 08:13 AM
Waterford
, New York
Regards,
Larry
200ah lithium batteries installed, they fit in box. Dc to dc charger installed, solar configured and charger converter indicating it sees lithium. Batteries show 100% after charging overnight. On to testing. As soon as the refrigerator cools down I’m going to pull the plug and see how long I 200ah last me.
06-05-2023, 11:46 AM
Waterford
, New York
Charged batteries to 100% Friday and shut down charger converter. After two overcast days the batteries were down to 50% this morning. The sun is out and the solar charging has them back to 100%. It looks like I can go four days without any charge at all running Norcold electric refrigerator. My expectations have been exceeded. I’m going to be very happy with this setup.
06-05-2023, 12:39 PM
2007 16' International CCD
Somewhere
That’s great, congratulations. To help us understand this better, which model fridge and what were the ambient temperatures day and night?
06-05-2023, 12:43 PM
2022 16' Basecamp
Chapel Hill
, North Carolina
You may want to take a look at this thread I started this morning on in the Basecamp forum:
https://www.airforums.com/forums/f40...tc-244096.html
06-05-2023, 01:05 PM
Waterford
, New York
The fridge is the Norcold N8dc and the daytime temps in the eighty’s and nights in the sixties.
06-05-2023, 01:51 PM
Somewhere
From the Norcold website, here are the power rates for that fridge:
Listed Amp Draw: 12V/DC :
Standard Mode Night mode
7.9 5.7
So that would be almost 200Ah per day running full time in standard mode, but they cycle on and off frequently. Your use of 100Ah over two days indicates a 25-35% duty cycle at those ambient temperatures, which is quite efficient. You will use more on warmer days, and less on cooler days.
Good experience based data — thanks for providing it.
06-05-2023, 01:59 PM
2023 25' Globetrotter
2021 16' Bambi
Forest Lake
What he said.
What they said.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
06-05-2023, 02:09 PM
2021 16' Bambi
Forest Lake
There are numerous threads on installing lithium batteries, but sounds like you moved quickly and got it done. I put four inside under a twin bed and upgraded the solar controller. and replaced the sketchy charger with a Victron. (My vehicle doesn't support the DC/DC charger (fused too low), so the charging wire is disconnected.)
I strongly recommend the Victron shunt. You won't have to guess then about how fully charged the batteries are. I don't know how your FC is configured but you should be able to squeeze it in by the DC junction box.
2017 Audi Q7 3.0T
WBCCI 6343
06-05-2023, 05:55 PM
Waterford
, New York
I did not want to give up the storage under the bed( yes we always bring to much stuff) so I used the self heating battery’s and located them in the battery box. My tow vehicle supports 30 amps to the trailer so dc to dc charging works. I also like the feature in the Victron that it shuts down when the tow vehicle is not running. The batteries came with a charge level indicator which works for now but down the road I will most likely add the Victron shunt.
06-05-2023, 07:59 PM
1977 Argosy Minuet 6.0 Metre
2007 25' International CCD FB
2018 28' Flying Cloud
Vancouver
Larry, which model trailer do you have?
06-06-2023, 05:51 AM
Waterford
, New York
Flying Cloud 25fbq
06-06-2023, 06:44 AM
2022 16' Basecamp
Chapel Hill
, North Carolina
Who's battery did you choose, why, model number?
Do you have an Inverter in line?
06-06-2023, 07:39 AM
Waterford
, New York
Epoch S12100B was he most battery for the dollar and the highest capacity that would fit in box, I did rotate them 90 degrees from original Agm’s. Also needed battery’s with heating function since I live up east. I would have spent the extra money for the ones with Bluetooth monitoring but they were slightly larger and would not fit and at some point I’m going to add the Victron Bluetooth shunt so the function would be redundant.
06-06-2023, 07:40 AM
Waterford
, New York
Attachment 432839
Yes I do have inverter.
06-06-2023, 03:50 PM
2022 16' Basecamp
Chapel Hill
, North Carolina
Larry, looked at your choice of battery - looks like a great unit from specs and reviews BUT the largest then make is the 100Ah unit you purchased.
I'm figuring I will need 2 x 200Ah batteries but will try to start out with just one 200 Ah. Wish they made a 200!
Thanks for your info.
