Old 10-14-2021, 01:29 PM   #1
2022 27' Globetrotter
Moulton , Texas
Changing original batteries to lightweight batteries?
Yes I am sure there is a post on this, but scouring thru without matching search terms is not easy.
I just simply want to change the original cheap heavy batteries out for lightweight batteries to save some tongue weight. I will rarely if ever need the batteries except for maybe to keep the frig running while the trailer is temporarily unhitched from my Powerboost truck or the campground power.
I will assume I need lithium and some sort of heated model battery?
dannko is offline   Reply With Quote
Old 10-14-2021, 02:09 PM   #2
"Cloudsplitter"
Yes there are many, here is one.
I don't see an advantage for the heated version of lithium batteries, if there is one it's pretty small in an AS application.
POI...we have 360w of Zamp portable, two BB 100ah unheated batts, Boondocker lithium converter, charging thru the 7pin umbilical. KISS
Old 10-14-2021, 02:16 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
I agree that heated is not that big a deal unless you routinely camp out in areas that stay below freezing all day / for many days.
How long do you want to keep the fridge running? How much does your fridge pull?
Some have reported 3 A average drains on the new compressor fridges. That would get you up to 72AH a day. This is a significant issue for your lead acid batteries. It would be a challenge for a single 100AH lithium.
If you go cheap, a single Lithium is about $500 these days.
Old 10-14-2021, 03:24 PM   #4
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
If you do not need that much battery and just want to save weight, have you considered going with just a single battery lead-acid battery? You will save yourself about 60lbs. Or a single lithium, which will give me more AH than you have now with 2 lead acids, and save 90lbs.
thewarden is offline   Reply With Quote
Old 10-15-2021, 09:41 AM   #5
Moulton , Texas
Yes it is strictly about weight, as I will never boondock. I have a Ford Powerboost with 7.2kw onboard power supply, so yes maybe one battery is the best, or one lithium to save even more weight. These Airstreams are definitely tongue heavy compared to others.
Old 10-15-2021, 10:38 AM   #6
2017 23' Flying Cloud
Mesquite , Nevada
I purchased Lion Safari batteries on sale @ Costco and couldn't be happier.
Ken G is offline   Reply With Quote
Original and customized curtains and accessories, original bedspread and pillows, and original couch covers, bolsters, and pillows tan and gold hshovic Airstream Classifieds 1 04-11-2020 11:22 AM
Changing Tire Pressure When Changing Load Rating smithcreek Tires 22 05-16-2019 06:04 AM
2009 Airstream Sport 22' FB Travel Trailer Lightweight eBay Watch Airstreams on eBay 0 10-31-2009 12:40 PM
2008 airstream safari special edition 19ft.lightweight eBay Watch Airstreams on eBay 0 10-26-2009 09:40 AM
New and need a lightweight one! Bexxer@mac.c Member Introductions 9 02-11-2008 03:33 PM
