06-26-2021, 01:36 PM
2016 25' International
Morgan Hill
Drilling into kitchen/cabinet wall...how? AS QA problem
2016 International FB 25'
Just got back from a 5800 mile trip across the country from California to Wisconsin and back.
Trip was basically uneventful...meaning the AS performed great. Used AC extensively, Refrigerator was on 'auto' and kept things cold, plumbing was no issue.
BUT....
AS QA Control raised its head again.
Last time it was the flip up counter extension by the door that fell off. Only held on barely by a 1/4" of screw into the kitchen sidewall. I bolted it on with a backing plate...it ain't comin' off anytime soon.
This time....well the doors under the sink (curved ones with the round sink above) always seem not to be that well attached. First the ball bearings that serve as the closing clasp fall out. Now I check the hinges and note that they are loose. Go to tighten them and discover that one hinge only has ONE screw holding it to the wall. There's that QA problem.
Ok fine add another screw. Not so fast McGee! Seems AS didn't even drill a hole for a screw and since there's no hole AS didn't add the screw.
This is very tight quarters (can't get even a small hand drill in there) and the surface is laminated. Can't get a screw started or even a drill bit...it slides on the laminate. No room for a punch either.
Any suggestions?
06-26-2021, 01:41 PM
Morgan Hill
06-26-2021, 01:47 PM
Sag Harbor
, New York
Could you post a photo? Hard to picture IMO.
How about a small portable cordless right-angle drill of some kind? To get a small "pilot hole" started, so that any drill bit can find a "seat" of some kind, take a very sharp pointed kitchen paring knife, and gently rotate its pointed end right where you want to start the hole. Putting a layer of duct tape first will help you lay out and mark the exact location. If this knife is a good quality steel, the laminate will not damage the point IMO. You only need a place for a SHARP drill ~1/16" to find "home" then you can increase the size. There are some very small hand-held drill "chucks" which would let you do this all by hand, at least to get started.
A photo will help a lot IMO . . . nearby good hardware store opening early in the morning? Also good lighting in that space is important IMO. A battery camping lantern, or similar small task light perhaps.
"Where there's a will . . . there's a way!"
Good luck,
Peter
06-26-2021, 01:58 PM
Salem
, Oregon
Hi, seems like you could use the hole in the hinge to help guide your drill or self drilling screw.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
06-26-2021, 03:21 PM
Morgan Hill
the laminate prevents this without good pressure and the lack of access to do that is the problem.
06-26-2021, 03:22 PM
Morgan Hill
Agreed about the pic.....tried using Google pics and it wouldn't show.
06-26-2021, 03:42 PM
Sag Harbor
, New York
Per earlier post:
-- duct tape pad
-- mark location with small felt-tip marker
-- short sharp paring knife for first "guide divot"
-- hardware store in morning for short hand-held manual chuck of some kind
-- short drill bits if needed
Where there's a will, there's a way.
Don't expect a magic cure here IMO.
Invent your own future.
Happy trails,
Peter
06-26-2021, 04:42 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Can you "mark the spot" then remove the door and/or other hinges to pre-drill a small pilot hole - then put it back together again? I know it sounds like two steps back then three forward - but it may be the only way to get in there.
Shari
06-26-2021, 08:09 PM
2017 22' Sport
2021 27' Globetrotter
Geographicly
, Unbound
Houdini's Magic Tool
I've been in some very tight spaces with only a drill to get me out. This is what will do the trick:
https://www.amazon.com/gp/aw/d/B013UBXU3E/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1
Try to keep that a secret because it'll put you into the Hallowed Handyman Hall of Fame
For drilling a hole perfectly centered on a hinge screw opening:
https://www.amazon.com/Senrob-Centering-Drill-Alignment-Woodworking/dp/B07K1Q1HFR/ref=mp_s_a_1_15?dchild=1&keywords=vix+bit+hex&qid= 1624759103&sr=8-15
Another more well known trick.
Also: Use #17 split point tip
with coarse thread if possible. Oh and don't overtighten.
06-27-2021, 12:14 AM
Sag Harbor
, New York
Originally Posted by kbmwrs
. . . This is very tight quarters (can't get even a small hand drill in there) No room for a punch either.
. . . the lack of access to do that is the problem.
Not sure whether folks appreciate just how limited your access is IMO.
Hopefully you will luck out at the hardware store this morning, and find the right tools for the job.
Good luck,
Peter
PS -- Because you started this thread, feel free to open the door for a discussion of attaching photos. [hot link in blue] This can be challenging the first time, but once you get the hang of it, it goes very quickly, and vastly improves the quality of the communication here IMO.
"A picture is worth . . . "
06-27-2021, 12:21 AM
Sag Harbor
, New York
Good suggestions . . . wondering, however, if he has room for these:
https://www.amazon.com/dp/B013UBXU3E...=ATVPDKIKX0DER
https://www.amazon.com/Senrob-Center...759103&sr=8-15
. . . For drilling a hole perfectly centered on a hinge screw opening:
Including the drill itself, and room to line up these bits with the hinge holes inside the cabinet, access may be too limited IMO.
Peter
06-27-2021, 09:50 AM
Charleston
, South Carolina
What are the dimensions of the space you are working in? The angle drill attachment might take up the least amount of space. A sharp bit should be able to penetrate the laminate. Cutting the bit in half might give you the extra room but still allow it to do the job. A Dremel tool also comes to mind for tight quarters.
Instagram @coasttocoastphotoatl
06-27-2021, 11:02 AM
Morgan Hill
Lets see if pic works
It does. So this is a pic of the top hinge on the right side door under the round sink. You can see that the hinge has ONE screw holding it. I thought I could just attach another screw where one is missing. NOPE. There is not even a hole where a previous screw would have been.
Since there is no hole there to begin with a screw will not dig into the wall....being that the wall is laminated a screw won't dig in.
What makes things difficult is that the sink is only 4 inches from this. So getting a drill in there with pressure isn't possible.
So I KNOW where to put a hole. That's not the problem. Its drilling in such a tight area. I'll look into that 90 degree drill....may be the answer.
06-27-2021, 12:18 PM
Sag Harbor
, New York
Excellent thanks!
As appeared to be the case, judging from your earlier posts IMO.
Just use a fine felt-tip marker in the curved end of that open slot for the new screw, to mark most of the circle available inside that slot, and then remove the hinge IMO. Previous posts contain suggestions for using duct tape, a sharp small paring knife, and other various tools, to get started IMO.
The correct size diameter pilot hole will work perfectly well in the plywood casework for that cabinet -- neither too small nor too large. Drill sample pilot holes in a separate piece of similar plywood [Baltic Birch, Maple, or other veneer-core -- TBD], to see if your new screws "hold" well, without binding in the plywood. When you use a pan-head sheet metal screw for this, its thread is sharp enough to "self tap" the receiving plywood for a solid "hold."
-- Guessing you will be needing either a #6 or #8 x 3/4" (~ 5/8" under the screw head) stainless steel pan-head screw for this +/- .
-- Does not have to be SS -- regular steel is OK if not getting wet, plus the stainless is softer and easier to damage when you insert the screw.
Would also suggest removing any other similar screws to make sure that their pilot holes ares sized correctly. Often the factory workers do not take the proper amount of time to pay attention to small details like, as you have noted in general.
-- One missing pilot hole, and one missing screw, appear to be just the tip of the iceberg here as to "quality control" IMO.
Have fun!
Peter
06-27-2021, 12:38 PM
2013 28' Flying Cloud
Cohasset
, Massachusetts
tight quarters
[QUOTE=kbmwrs;2509228]2016 International FB 25'
"…This is very tight quarters (can't get even a small hand drill in there) and the surface is laminated. Can't get a screw started or even a drill bit...it slides on the laminate. No room for a punch either…"
In my cabinet work I use a variation of these two items:
Wallace: 2013 GMC Sierra 2500 D-Max
Gromit: 2013 Flying Cloud 28
_______________________________
06-27-2021, 12:42 PM
Sag Harbor
, New York
Originally Posted by callmedave
. . . In my cabinet work I use a variation of these two items.
With only 4" of clearance?
. . . What makes things difficult is that the sink is only 4 inches from this. So getting a drill in there with pressure isn't possible.
Earlier posts cover this "tight quarters" situation in more detail IMO.
Peter
06-27-2021, 12:46 PM
Sag Harbor
, New York
PS --
If you could post a photo taken from in front of the cabinet, showing that same hinge base plate, and the nearby sink 4" away [and presumably hanging down quite a bit], that might help others "see" the situation IMO.
Peter
06-27-2021, 01:06 PM
Cohasset
, Massachusetts
Peter
__________________________________________________ _____
Sure thing, I encounter this a lot. The right angle attachment is chucked into standard corded or battery powered drill. The head is 1 ˝"(as shown), the 3/32" bit is about 1 ⅞". Overall is 3 ⅝", <4". There are also #2 phillips-head driver bits that are ~1 ˝" or lesscwhen chucked in the RA adaptor, so there is also <4"clearance. So, yes this will and does work.
Dave
06-27-2021, 01:16 PM
2014 27' FB International
Lewisville
06-27-2021, 01:20 PM
Sag Harbor
, New York
. . . Sure thing, I encounter this a lot.
Dave
Thanks Dave.
Peter
PS and thank you NO NOIZE.
